8 3/4 yokes #2081448
05/27/16 07:24 PM
05/27/16 07:24 PM
duster408 Offline OP
Does anyone know the difference in the yoke seals between a 742 and 489 case. I changed my seal and it leaks worse now and the yoke is not grooved.
Re: 8 3/4 yokes [Re: duster408] #2081457
05/27/16 07:39 PM
05/27/16 07:39 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
they are not the same.
Re: 8 3/4 yokes [Re: duster408] #2081459
05/27/16 07:43 PM
05/27/16 07:43 PM
Pattison Texas
Pattison Texas
7216 national is for 742
Re: 8 3/4 yokes [Re: duster408] #2081461
05/27/16 07:45 PM
05/27/16 07:45 PM
Pattison Texas
Pattison Texas
5126 is for the 489
Re: 8 3/4 yokes [Re: CSK] #2081623
05/28/16 01:07 AM
05/28/16 01:07 AM
I'd pack the back side covering the spring totally with heavy grease to keep the spring in place. I'd get a piece of pipe of the right dia & wide enough to cover a good portion of the seal face & use it to drive it in & get it started straight with a medium whack then continue to drive it home with as few strokes as possible as more hitting increases the chances of fubaring it. several good strokes is all it should take
Re: 8 3/4 yokes [Re: RapidRobert] #2081799
05/28/16 12:43 PM
05/28/16 12:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Does that procedure work for both seals ... he did ask if the seals were different ... not how to install it . wink
Re: 8 3/4 yokes [Re: RapidRobert] #2081902
05/28/16 05:08 PM
05/28/16 05:08 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
That is a good to know tip. As a matter of fact my club had a diff clinic at my shop on Thursday and we broke down, inspected, cleaned and reassembled a 741 single track case with 3.23 gears. It had a 10 spline yoke with straps and the seal area was still good so we just cleaned it, greased it and reused the seal because the diff owner had not bought a seal, he thought we were just going to clean off the dirt and drop it into the housing, install the axles and set the end play. But the 3rd member was stiff, the spider gears would not turn and we needed to look at the bearings to be sure they were still usable. Since it is going into a '71 Charger cruiser/show toy it will be fine. We did adjust the backlash with a dial indicator so it should be good for years to come. And now the owner knows more about diffs than he did when we started.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 8 3/4 yokes [Re: duster408] #2081903
05/28/16 05:09 PM
05/28/16 05:09 PM
Pattison Texas
Pattison Texas
actually the correct seal for the 742 has no spring & the lip seal is made of leather.
Re: 8 3/4 yokes [Re: CSK] #2081908
05/28/16 05:17 PM
05/28/16 05:17 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Somebody is paying attention grin up
csk, you maybe , but my comment is meant for some one else. grin
Re: 8 3/4 yokes [Re: duster408] #2081960
05/28/16 07:50 PM
05/28/16 07:50 PM
Can the 2 be interchanged? Is the inner or outer diameter different?
Re: 8 3/4 yokes [Re: duster408] #2081974
05/28/16 08:38 PM
05/28/16 08:38 PM
Pattison Texas
Pattison Texas
as i said, they are different.
Re: 8 3/4 yokes [Re: CSK] #2082051
05/28/16 10:51 PM
05/28/16 10:51 PM
Oh OK I did not know that they were different (as far as spring/no spring). Noted!
Re: 8 3/4 yokes [Re: CSK] #2082387
05/29/16 05:26 PM
05/29/16 05:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Correct as in "factory original" or correct as in "it fits/functions"?
Most 742 seals nowadays are rubber and have a garter spring.
Re: 8 3/4 yokes [Re: duster408] #2082460
05/29/16 07:54 PM
05/29/16 07:54 PM
Pattison Texas
Pattison Texas
out of the last 5 I bought 4 were leather National brand & 1 rubber & spring from Cass @ DR diff.
