Re: 8 3/4 yokes
[Re: CSK]
#2081623
05/28/16 01:07 AM
05/28/16 01:07 AM
RapidRobert
I'd pack the back side covering the spring totally with heavy grease to keep the spring in place. I'd get a piece of pipe of the right dia & wide enough to cover a good portion of the seal face & use it to drive it in & get it started straight with a medium whack then continue to drive it home with as few strokes as possible as more hitting increases the chances of fubaring it. several good strokes is all it should take
Re: 8 3/4 yokes
[Re: RapidRobert]
#2081799
05/28/16 12:43 PM
05/28/16 12:43 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
I'd pack the back side covering the spring totally with heavy grease to keep the spring in place. I'd get a piece of pipe of the right dia & wide enough to cover a good portion of the seal face & use it to drive it in & get it started straight with a medium whack then continue to drive it home with as few strokes as possible as more hitting increases the chances of fubaring it. several good strokes is all it should take Does that procedure work for both seals ... he did ask if the seals were different ... not how to install it .
Re: 8 3/4 yokes
[Re: RapidRobert]
#2081902
05/28/16 05:08 PM
05/28/16 05:08 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I'd pack the back side covering the spring totally with heavy grease to keep the spring in place. I'd get a piece of pipe of the right dia & wide enough to cover a good portion of the seal face & use it to drive it in & get it started straight with a medium whack then continue to drive it home with as few strokes as possible as more hitting increases the chances of fubaring it. several good strokes is all it should take That is a good to know tip. As a matter of fact my club had a diff clinic at my shop on Thursday and we broke down, inspected, cleaned and reassembled a 741 single track case with 3.23 gears. It had a 10 spline yoke with straps and the seal area was still good so we just cleaned it, greased it and reused the seal because the diff owner had not bought a seal, he thought we were just going to clean off the dirt and drop it into the housing, install the axles and set the end play. But the 3rd member was stiff, the spider gears would not turn and we needed to look at the bearings to be sure they were still usable. Since it is going into a '71 Charger cruiser/show toy it will be fine. We did adjust the backlash with a dial indicator so it should be good for years to come. And now the owner knows more about diffs than he did when we started.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: 8 3/4 yokes
[Re: duster408]
#2081903
05/28/16 05:09 PM
05/28/16 05:09 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
actually the correct seal for the 742 has no spring & the lip seal is made of leather.
Re: 8 3/4 yokes
[Re: CSK]
#2081908
05/28/16 05:17 PM
05/28/16 05:17 PM
Posts: 22,724 Bitopia
jcc
Bitopia
Somebody is paying attention csk, you maybe , but my comment is meant for some one else.
Re: 8 3/4 yokes
[Re: duster408]
#2081974
05/28/16 08:38 PM
05/28/16 08:38 PM
CSK
Pattison Texas
as i said, they are different.
Re: 8 3/4 yokes
[Re: CSK]
#2082051
05/28/16 10:51 PM
05/28/16 10:51 PM
RapidRobert
Oh OK I did not know that they were different (as far as spring/no spring). Noted!
Re: 8 3/4 yokes
[Re: CSK]
#2082387
05/29/16 05:26 PM
05/29/16 05:26 PM
Posts: 25,969 Rio Linda, CA
John_Kunkel
Rio Linda, CA
actually the correct seal for the 742 has no spring & the lip seal is made of leather. Correct as in "factory original" or correct as in "it fits/functions"? Most 742 seals nowadays are rubber and have a garter spring.
Re: 8 3/4 yokes
[Re: duster408]
#2082460
05/29/16 07:54 PM
05/29/16 07:54 PM
CSK
Pattison Texas
out of the last 5 I bought 4 were leather National brand & 1 rubber & spring from Cass @ DR diff.
