2006 ram ac problems #2082130
05/29/16 01:04 AM
05/29/16 01:04 AM
fredericksburg,va
cudaman1969 Online sleepy OP
cudaman1969  Online Sleepy OP
fredericksburg,va
Has anyone on here have ac problems (not working for whatever reason) ? Mine stopped and I need some idea of the fixes before going to the dealer-stealer. My compressor is good but won't stay on. Put 12 volts to compressor and blows good cold air. Replaced hp switch too. 2006 3500 CD
Re: 2006 ram ac problems [Re: cudaman1969] #2082135
05/29/16 01:33 AM
05/29/16 01:33 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Low on freon maybe?
Re: 2006 ram ac problems [Re: stumpy] #2082149
05/29/16 02:33 AM
05/29/16 02:33 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Best to get it to a shop that specializes in AC
Abe Lincoln
Re: 2006 ram ac problems [Re: cudaman1969] #2082330
05/29/16 02:27 PM
05/29/16 02:27 PM
fredericksburg,va
fredericksburg,va
Not the answers I'm asking for
Re: 2006 ram ac problems [Re: cudaman1969] #2082343
05/29/16 03:09 PM
05/29/16 03:09 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
The power output is to the a/c compressor is controlled by the TIPM or fuse box next to the drivers side battery. You will most likely need a scan tool to check for fault codes and actuate the power supply manually. First check for an a/c compressor circuit open fault in the TIPM. Then use the scanner to check for a possible broken wire or bad connection. The compressor clutch coil is the most common thing to fail on these trucks but since you can jump yours to make it activate the TIPM or bad wire is likely the problem.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2006 ram ac problems [Re: 71yelladustr] #2082475
05/29/16 08:22 PM
05/29/16 08:22 PM
fredericksburg,va
fredericksburg,va
Thank you, it does try to turn. Goes about a half turn, stops, haft turn, stops, this goes on until I turn off the switch, also the engine surges each time it tries to turn. I guess it's modual time.
Re: 2006 ram ac problems [Re: cudaman1969] #2082522
05/29/16 09:51 PM
05/29/16 09:51 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Maybe too much freon??????? IDK....Seems like I remember a buddy of mine years ago kept adding and the comp stopped turning. Bled some out and all was well.
