72 scamp rear #2082263
05/29/16 12:26 PM
05/29/16 12:26 PM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
Hello all ! Glad to know moparts is still here and doing quite well ! I have a question im hoping someone might know . Ive decided to build that old scamp body ive had behind the shop so i sent it off to a good freind to have it preped and sprayed i still have my old van motor that ill refresh and drop in it its a stout little 318 thats supposed to male about 400 horsepower acording to the build i copied ( sure we've all read the 318 cheap as dirt build right?) And i think i want to mate it to a 904 to take advantage of that quicker first gear thereay or may not be a trans brake involved havent decided how balls out i wann go yet question is the car is a 2 door factory small block (318 by build tag but last owner had a 360 in it ) and factory manual so i wondersd what rear is it supposed to have and would ot be any good to keep bavk there with this plan ? Last owner sayed he drove ot like it was stolen with a 360 and wasnt gentle with it so i figure ot would be ok for a little while but i dont wanna snap off a yoke the first time out either .any thoughts or expertise would be greatly appreciated. Thanks guys.
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
Re: 72 scamp rear [Re: gogo318] #2082303
05/29/16 01:48 PM
05/29/16 01:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Compare it to these pics and let us know what's in it now. http://www.moparts.org/Tech/Archive/axle/6.html
Re: 72 scamp rear [Re: gogo318] #2082358
05/29/16 03:53 PM
05/29/16 03:53 PM
what Stump said, see what you have & if it has the ring gear bolts for the pig on the front side (8&3/4) you're set. If not then that is what I would search for either an OE A body one which will have SBP (they are getting pricey) or get a C body or 1/2 ton truck 8&3/4 & have Moser cut down the axles/housing so you can have BBP for your wheels
