Re: 2006 ram ac problems
[Re: stumpy]
#2082149
05/29/16 02:33 AM
05/29/16 02:33 AM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
Best to get it to a shop that specializes in AC
Abe Lincoln
[Re: cudaman1969]
#2082343
05/29/16 03:09 PM
05/29/16 03:09 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
The power output is to the a/c compressor is controlled by the TIPM or fuse box next to the drivers side battery. You will most likely need a scan tool to check for fault codes and actuate the power supply manually. First check for an a/c compressor circuit open fault in the TIPM. Then use the scanner to check for a possible broken wire or bad connection. The compressor clutch coil is the most common thing to fail on these trucks but since you can jump yours to make it activate the TIPM or bad wire is likely the problem.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#2082475
05/29/16 08:22 PM
05/29/16 08:22 PM
Posts: 8,341 fredericksburg,va
cudaman1969
fredericksburg,va
The power output is to the a/c compressor is controlled by the TIPM or fuse box next to the drivers side battery. You will most likely need a scan tool to check for fault codes and actuate the power supply manually. First check for an a/c compressor circuit open fault in the TIPM. Then use the scanner to check for a possible broken wire or bad connection. The compressor clutch coil is the most common thing to fail on these trucks but since you can jump yours to make it activate the TIPM or bad wire is likely the problem. Thank you, it does try to turn. Goes about a half turn, stops, haft turn, stops, this goes on until I turn off the switch, also the engine surges each time it tries to turn. I guess it's modual time.
