Re: 440 source stroker [Re: oldtimer5151] #2080677
05/26/16 02:25 PM
05/26/16 02:25 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I have yet to find a set of Source rods that were right after properly cycling the bolts, or a crank that didn't have taper on more than one journal. Rods were always resized before use, and the taper was never outside of factory tolerance but was on the high limit regularly. It's good value stuff even with spending a little to make it "right". It's not "good out of the box".
Re: 440 source stroker [Re: oldtimer5151] #2080703
05/26/16 02:48 PM
05/26/16 02:48 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Save the hassle and order Molnar. I've had one experience with Source parts and it resulted in a broken rod and junk motor.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: 440 source stroker [Re: oldtimer5151] #2080754
05/26/16 04:03 PM
05/26/16 04:03 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
As stated, i would check/have checked any OOTB machined "tolerances".
I'm running Source rods, but cycled the bolts & had them sized.
I know of Eagles that have had to have the same done. twocents
72 Plymouth Roadrunner 11.08@123.25
Re: 440 source stroker [Re: Eric] #2080767
05/26/16 04:41 PM
05/26/16 04:41 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Not to throw poop into the game but tell the whole story Eric. You bought a used engine that had the CHEAP I beem rods that most guys wouldn't use in a stock rebuild and were discontinued years ago. ALL parts need checked. Lots of good companies out there and I use them all. My old 440source (500 cubic inch) assembly had 275 (8 second) passes on it before I found a crack in the block. A friend is still using that same assembly years later in his street car and zero corrections were needed with the proper bearings.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440 source stroker [Re: moper] #2080833
05/26/16 06:35 PM
05/26/16 06:35 PM
Aubrey, Texas
O
oldtimer5151 Offline OP
O
Aubrey, Texas
You are right. Stroker cranks have taper. I know 2 engine builders (one in the Hot Rod Hall of Fame) that will not use certain company's cranks because of taper. A lot of engine builders use surface mic. that are only graduated into thousands, instead of tents. Optical comparators check the radius, t.i.r, and taper. Profile lometer to check finish. Now tell me again how you check crankshaft dimensions? In 1964, I was running a grinder and retired 35 years- running 6 axis cnc machines. I guess that I just have got old.
Re: 440 source stroker [Re: oldtimer5151] #2080839
05/26/16 06:46 PM
05/26/16 06:46 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I was asking about side clearance because that is how I found out the lower rod bearing shell had the bearing locator notch in the wrong place pushing the bearing into the radius of the crank rod journal.
Re: 440 source stroker [Re: 451Mopar] #2080843
05/26/16 06:52 PM
05/26/16 06:52 PM
Aubrey, Texas
O
O
Aubrey, Texas
That was good .016 to .018. Crank end play was .008. A friend of mine had .045 for side clearance on a 499. Seams excessive to me, but i'm just set in my ways.
Re: 440 source stroker [Re: oldtimer5151] #2080851
05/26/16 07:08 PM
05/26/16 07:08 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Well now if you checked everything and it speced out, where does that leave you? A spun rod bearing. Lost it's crush.. lack of oil, aerated oil, or over revved, sometimes you get that one [censored] bearing too, detonation (both audible & silent), heck, even a backfire. Lots of things can cause a bearing to spin. I seen Callies cranks do the same. Usually do to the above mentioned.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: 440 source stroker [Re: oldtimer5151] #2080859
05/26/16 07:21 PM
05/26/16 07:21 PM
Who assemble that motor?
Re: 440 source stroker [Re: Cab_Burge] #2080879
05/26/16 08:00 PM
05/26/16 08:00 PM
Aubrey, Texas
O
O
Aubrey, Texas
Ya'll are getting this all wrong. I had access to any kind of measuring tool that I would have needed. I JUST DID NOT DO IT! I ASSUMED that the complete assembly hand been gone over. It was my fault. I spun #4 and #4 only. All other bearings did not have the break in worn off. The rest of the journals were ok. It did not run out of oil. That rod journal was too tight and I did not find it. One and a half pass later it quit-1/8 mile. Bearing welded to journal, and rod end shattered. Rod next to it looked good. Main above it ok. Nothing in oil galley.
Re: 440 source stroker [Re: oldtimer5151] #2080887
05/26/16 08:18 PM
05/26/16 08:18 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
John the rotating assembly was brand new. Even the cheap discontinued rods they rated at 1000hp lol . I guess what I'm saying is at the price of the source stuff it's really no deal compared to K1 or Eagle or Molnar. So keep your options open even on a budget build.
Re: 440 source stroker [Re: Eric] #2080910
05/26/16 08:57 PM
05/26/16 08:57 PM
Aubrey, Texas
O
O
Aubrey, Texas
Thanks Eric, My next build will definitely be one of them.
Re: 440 source stroker [Re: oldtimer5151] #2251958
02/12/17 12:16 AM
02/12/17 12:16 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
All I can say is... "It happen's" Been down that road..
Bottom Line.... Check it over well.... Oh and one more time...
Keep Building them Engines. OLD FARTS RULE !!!!!
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: 440 source stroker [Re: racerhog] #2251984
02/12/17 12:52 AM
02/12/17 12:52 AM
A problem on SB's is the oil rushes by the #4 main so fast that the oil has a problem making the turn & the rods on either side can & have failed. I ain't up on BB's but reportedly they can have a similar but lesser same issue (& their routing as you know is different). I would definitely open up the galley to main passages (Mcandless & others have writeups on this) & consider bypass direct feed the other end of the gallery. Just thinking out loud & I hope it works out (I am considering a 543 'source kit) but at the moment 2K for 100 extra cubes ain't practical right now.
Re: 440 source stroker [Re: oldtimer5151] #2251997
02/12/17 01:06 AM
02/12/17 01:06 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
ohio crank stroker kits are good i use them all the time,any one else has on here ?
Re: 440 source stroker [Re: dart games] #2252004
02/12/17 01:17 AM
02/12/17 01:17 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
me too
511ci
1.39 9.85 - 137 mph
Re: 440 source stroker [Re: oldtimer5151] #2252030
02/12/17 02:19 AM
02/12/17 02:19 AM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
On one of my motors oil starvation we blaimed the pick up sucking air, on a 452".
Section 8 Racing We are nuts about racing.
Re: 440 source stroker [Re: dart games] #2252059
02/12/17 03:56 AM
02/12/17 03:56 AM
I've built around 12 stroker motors,B and RB, one Hemi, with Ohio Crankshaft CO cranks up I bought one of their blem 4.25 stroke B cranks for myself that had a badly bent flywheel flange when I got it puke shock They replaced it for no charge with a new one and paid the freight both ways up bow I had bought six other new ones on that order so that may have had some bearing on their decision making shruggy
I will buy more parts from them in the future thumbs
if your going wild looking for every last HP buy the really good stuff up If your going mild with your build buy the mild parts twocents
Re: 440 source stroker [Re: pittsburghracer] #2252720
02/13/17 12:58 AM
02/13/17 12:58 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Originally Posted By pittsburghracer
Originally Posted By oldtimer5151
440 source would not replace or discount any amount on another stroker kit.
Please tell me you can't be serious. There are many, many reasons for a bearing to spin. Any and all clearances have to be checked whether its a stock type of rebuild or high performance. It takes me hours to properly clean and prep a block before I start assembly. If unsure of yourself leave the job to a professional as its harder than it looks.
Well said.
