Will max wedge rocker arms work on 915 BB heads?
#208080
01/29/09 07:43 PM
01/29/09 07:43 PM
Posts: 493 BFE
blue67440's
BFE
Wanting to install adjustable rocker arms as part of my 67 440 HP engine build, can I use max wedge ductile iron rocker arms on my 915 heads and if so what changes will I have to make. Thanks blue
XP29L72 A833 in 881
XP29L72 A727 in 881
Re: Will max wedge rocker arms work on 915 BB heads?
[Re: ScottSmith_Harms]
#208085
01/29/09 11:21 PM
01/29/09 11:21 PM
Posts: 493 BFE
blue67440's
BFE
Scott, I owe you , thanks!! blue
XP29L72 A833 in 881
XP29L72 A727 in 881
#208086
01/29/09 11:37 PM
01/29/09 11:37 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
If they are used I'd reccomend sending them to RAS for a rework, he does REALLY nice work and if you want to upgrade with new shafts and collars he has top notch stuff. I had mine done there and they came out awesome.
Scott,on a rework,ball park on cost? The reason I ask is that the original Max Wedge rocker arms are not a true 1.5 ratio.Is it really worth the expense versus new 1.5 ductile iron rockers?
[Re: 62maxwgn]
#208087
01/29/09 11:44 PM
01/29/09 11:44 PM
Posts: 493 BFE
blue67440's
BFE
Are they less/more than 1.5?
blue
XP29L72 A833 in 881
XP29L72 A727 in 881
