Will max wedge rocker arms work on 915 BB heads? #208080
01/29/09 07:43 PM
01/29/09 07:43 PM
BFE
blue67440's Offline OP
BFE
Wanting to install adjustable rocker arms as part of my 67 440 HP engine build, can I use max wedge ductile iron rocker arms on my 915 heads and if so what changes will I have to make.
blue
XP29L72 A833 in 881 XP29L72 A727 in 881
Re: Will max wedge rocker arms work on 915 BB heads? [Re: blue67440's] #208081
01/29/09 07:56 PM
01/29/09 07:56 PM
AndyF Online content
AndyF  Online Content
Sure, they should just bolt on there.
Re: Will max wedge rocker arms work on 915 BB heads? [Re: AndyF] #208082
01/29/09 08:38 PM
01/29/09 08:38 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If they are used I'd reccomend sending them to RAS for a rework, he does REALLY nice work and if you want to upgrade with new shafts and collars he has top notch stuff. I had mine done there and they came out awesome.
Re: Will max wedge rocker arms work on 915 BB heads? [Re: AndyF] #208083
01/29/09 11:11 PM
01/29/09 11:11 PM
BFE
BFE
Do you have to take the old style pedestals off and just bolt them directly to the head?
blue
Re: Will max wedge rocker arms work on 915 BB heads? [Re: blue67440's] #208084
01/29/09 11:20 PM
01/29/09 11:20 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, sounds like they were on 62/63 286 MW heads (which require the stands) 64 518 heads did not. The rocker shafts and all will bolt on the 915's no problem.
Re: Will max wedge rocker arms work on 915 BB heads? [Re: ScottSmith_Harms] #208085
01/29/09 11:21 PM
01/29/09 11:21 PM
BFE
BFE
Scott, I owe you , thanks!!
blue
Re: Will max wedge rocker arms work on 915 BB heads? [Re: ScottSmith_Harms] #208086
01/29/09 11:37 PM
01/29/09 11:37 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Scott,on a rework,ball park on cost? The reason I ask is that the original Max Wedge rocker arms are not a true 1.5 ratio.Is it really worth the expense versus new 1.5 ductile iron rockers?
Re: Will max wedge rocker arms work on 915 BB heads? [Re: 62maxwgn] #208087
01/29/09 11:44 PM
01/29/09 11:44 PM
BFE
BFE
Are they less/more than 1.5?
blue
Re: Will max wedge rocker arms work on 915 BB heads? [Re: blue67440's] #208088
01/29/09 11:52 PM
01/29/09 11:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
They should be the same as stock, not too far off 1.5 but as mentioned, a shade off. I think I paid about $500.00 which included new chrome shafts, refurbish the tips, and aluminum collars instead of springs, and all new adjusters, that was about 4 years ago.
Re: Will max wedge rocker arms work on 915 BB heads? [Re: blue67440's] #208089
01/30/09 12:22 AM
01/30/09 12:22 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
blue
Closer to 1.4
