I Did the speedo Calibration.... Found My Fuel Issue #2079490
05/24/16 06:57 PM
05/24/16 06:57 PM
MR_P_BODY Offline OP
I did the speedo calibration today and got that done..
then on the way back I stopped and did a full on pass
and after I got that done the fuel system seem to shut
down.. this was well after I made the hard run.. it stayed
fired but I didnt understand the shut down.. also found
a MAJOR oil leak at the pass side valve cover.. the cover
is very close to the intake so I'm gonna double up that
gasket to see if thats the problem..I had issues there before
but I have to figure out the fuel issue... it ran REAL
STRONG on the run
Of course I had to make my pass on the drive way
to the ford proving grounds... LOL
EDIT
I forgot to turn off the OD and I was surprised
that the OD didnt even slip on the full all out
pass... I didnt think it would hold in OD without
reving up(slipping).. but I sure wouldnt want to
do that very often... I wish I would have opened
up the dumps
wave
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2079540
05/24/16 08:31 PM
05/24/16 08:31 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Glad you got it out and got to enjoy it! It's one badazz little ride!
Randy
Re: I Did the speedo Calibration [Re: Dartin] #2079545
05/24/16 08:41 PM
05/24/16 08:41 PM
Thanks Randy... it ran real strong.. I wish I
would have opened the dumps... there were a few
ford guys coming out that gave me the thumbs up
when I pulled into my driveway.. one guy stopped
and said.. thats one bad a$$ little truck.. he
never seen one before
wave
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2079546
05/24/16 08:57 PM
05/24/16 08:57 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Mike glad to hear it ran well. I'm sure you will have the fuel deal figured out in no time. Jim
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2079548
05/24/16 09:00 PM
05/24/16 09:00 PM
As a test I'm gonna pull the roll over valve to
see if thats the restriction in the vent... thats
sorta the way it acted.. it was after the full on
boggy which might have had a vac in the tank.. its
worth a check... I have a #an8 vent... if that is
the issue.. I will add a side to side line with a
drop below the tank so it would be above the tank IF
I were upside down... the side to side has to go past
the sides of the tank so they would be higher than the
tank if its on its side
wave
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2079589
05/24/16 10:29 PM
05/24/16 10:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
With all of the crap you've gone through on that beast,that must of felt great and rewarding............... thumbs
Re: I Did the speedo Calibration [Re: Thumperdart] #2079598
05/24/16 10:37 PM
05/24/16 10:37 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Nice Mr.P. to be back in the saddle . Gotta love those small blocks.... performance-wise do you think the overdrive trans Hurts much in the 1/4. I know that they're heavier and have a lot of rotating Mass... but it seems like on these newer cars the more gears they add the quicker they run
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2079622
05/24/16 11:12 PM
05/24/16 11:12 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Good to see you have that thing figured out, bet it felt good to get a little pass on it, Congrats
Re: I Did the speedo Calibration [Re: WHITEDART] #2079623
05/24/16 11:14 PM
05/24/16 11:14 PM
It adds 47# to a 727 I cant say on the mass as of
yet but this is for the street also so I will take
what I get.. power to weight it should run 10.0 or
just under that... all I wanted was low 10s
wave
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2079669
05/25/16 12:06 AM
05/25/16 12:06 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
That is one awesome looking Rampage! And of course, Rampage is my favorite mini truck. I'm glad you had it out on the road.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2079756
05/25/16 01:46 AM
05/25/16 01:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The W5's have a much nicer top rail to seal up those valve covers..... If you feel like dancing with the devil again!
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2079762
05/25/16 01:52 AM
05/25/16 01:52 AM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
Love that little truck! Mr p if you don't mind can you refresh us on the motor combo? Was it a w2?
Re: I Did the speedo Calibration [Re: J_BODY] #2079764
05/25/16 01:53 AM
05/25/16 01:53 AM
They are fixed now... but I wanted to get it
sorted out with the W-2s then change back over
unless I buy some new alum heads
wave
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2079844
05/25/16 09:07 AM
05/25/16 09:07 AM
moparx Offline
moparx  Offline
good job mr. p ! up glad you got a good pass in and nothing major popped up to spoil the fun ! how big is your return line on your fuel system ? did you pop the cap on the gas tank for the ride home ?
beer
Re: I Did the speedo Calibration [Re: moparx] #2079887
05/25/16 10:30 AM
05/25/16 10:30 AM
beer
#8 supply #8 return... no I didnt open the cap..
that was just a couple hundred feet from my driveway..
I'll fix the valve cover and take it out again with the
roll over valve off and the cap open
wave
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2079936
05/25/16 12:16 PM
05/25/16 12:16 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Mike that is an AWESOME looking little truck. So if you take it on Power Tour or Drag Week, will you use a trailer? I think you said in one of your earlier post the bed was no longer usable as a truck bed.
Good luck with it and hope for many years of fun.
Jerry
Old Geezer Racing
Re: I Did the speedo Calibration [Re: SCATPACK 1] #2079957
05/25/16 12:39 PM
05/25/16 12:39 PM
Jerry
I'll take a trailer pretty much anywhere thats not
local... the bed is non existent being that the battery
and fuel tank and bars are in there.. the tank is 18 gals..
I have space in the back 2 corners next to the tank for
a tool bag on one side and my small alum floor jack in
the other corner
EDIT
This pic was before I finished the tank.. I had
to add the vent and filler cap and the mounts for
the tank
wave
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2080111
05/25/16 04:10 PM
05/25/16 04:10 PM
Found my oil leak... I can be such a BONE HEAD
at times... I had to clearance the valve covers
for the springs and push rods... I guess I got
carried away with clearancing... the gasket was
sitting on about .010 at max on the cover flange.. with
any heat and or crank case pressure the oil was gonna
come out.. damn I can be stupid at times.. this covers
were for my W-5s and I didnt think there would be a
issue.. WRONG... I have a few spare covers so I grabbed
another and working with it to fit... then to fix the
horn.. it has a mind of its own and blows when it feels
like(must be grounding in the column with the vibrations)
wave
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2080783
05/26/16 05:09 PM
05/26/16 05:09 PM
I found another big oil leak today.. the front
rubber seal on the pan blew out at the corner
of the timing cover and the pan.. the little
tittie on the rubber seal tore off when I tried
pulling it in with pliers when I put it together
.. so I pulled the pan and will replace that tomorrow
.. also found my horn issue... its in the horn button
itself..looks like I'll have to order another horn button
assembly... L-body is the same.. but I think I have one
that a buddy has laying around
wave
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2082606
05/30/16 01:11 AM
05/30/16 01:11 AM
I got it all back together today so the leaks should be
all fixed..I'll pull the vent line next time out.. I
should say the rollover valve and the vent line.. and
I'll open the dumps... just curious
wave
