Picture Request: Fuel sender ground strap/Installed #207859
01/29/09 05:52 PM
01/29/09 05:52 PM
USA
Suregrip391 Offline OP
USA
Can anyone post me a picture of a ground strap that is installed on a car, for the fuel tank sending unit? Mine is missing and I want to see one in action! ..
Re: Picture Request: Fuel sender ground strap/Installed [Re: Suregrip391] #207860
01/29/09 06:16 PM
01/29/09 06:16 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Dont have a pic but all it is a thin strap with 2 open type clips.One snaps on the sender the other on the steel fuel line.I just make them from a piece of 12 gauge wire an eyelet and a small hose clamp.Total cost about 20 cents.That and it works better than the OE strap.Rocky
Chrysler Firepower
Re: Picture Request: Fuel sender ground strap/Installed [Re: therocks] #207861
01/29/09 06:47 PM
01/29/09 06:47 PM
USA
USA
Cool, thanks...I am familiar with what they look like, just was not certain as to how it mounted? On the fuel sending unit goes the rubber hose, on the oppisit side of the rubber hose is the fuel line which goes up front to the pump. Now, did the original ground strap mount just below the rubber hose on the sender itself where the hose goes on?
I was thinking of making my own also, but was going to try drilling a hole in the "extra material" of the fuel tanks outer flange area, pitting an eyelet on a wire and using a sheetmetal screw to fasten it and then mount the other end of the wire to the frame maybe? ...That should ground out the tank/sender, you think?
Re: Picture Request: Fuel sender ground strap/Installed [Re: Suregrip391] #207862
01/29/09 07:00 PM
01/29/09 07:00 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Re: Picture Request: Fuel sender ground strap/Installed [Re: Suregrip391] #207863
01/29/09 07:03 PM
01/29/09 07:03 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
You need to ground the sender rather than the tank. It will probably work, but if you ground the tank, you're relying on the sending unit, lock ring, and tank to all have clean, corrosion free contact for the ground path to work. Better ground the sending unit directly.
Re: Picture Request: Fuel sender ground strap/Installed [Re: In_The_Pink] #207864
01/29/09 07:03 PM
01/29/09 07:03 PM
USA
USA
Thanks In_The_Pink, thats what I needed! Appreciate it very much.
Re: Picture Request: Fuel sender ground strap/Installed [Re: Suregrip391] #207865
01/29/09 08:33 PM
01/29/09 08:33 PM
USA
USA
Im thinking some wire and these (see pic attached) will do the trick! Thanks guys!
Re: Picture Request: Fuel sender ground strap/Installed [Re: Suregrip391] #207866
01/29/09 10:01 PM
01/29/09 10:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why not just a piece of wire and a couple of little fuel line clamps?
Re: Picture Request: Fuel sender ground strap/Installed [Re: Suregrip391] #207867
01/29/09 10:43 PM
01/29/09 10:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
