727 Shift kit question? #2077864
05/21/16 09:02 PM
05/21/16 09:02 PM
Harlan, Ky
O
Orange_Duster Offline OP
O
Harlan, Ky
What does grinding the throttle valve shorter (as recommended in most all shift kits) do? Does it effect part throttle shift points or only full throttle shift points? Also does it effect the part throttle kick down feature?
Re: 727 Shift kit question? [Re: Orange_Duster] #2077869
05/21/16 09:10 PM
05/21/16 09:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Do you mean throttle valve or the governor valves ? Ron
Re: 727 Shift kit question? [Re: Orange_Duster] #2078104
05/22/16 04:08 AM
05/22/16 04:08 AM
Harlan, Ky
O
O
Harlan, Ky
I'm talking about the throttle valve in the valve body.
Re: 727 Shift kit question? [Re: Orange_Duster] #2078341
05/22/16 04:53 PM
05/22/16 04:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Grinding the end of the throttle valve allows you to apply more throttle without forcing a kickdown. Evidently the kit designers think this is a benefit, I don't see it.
Has no effect on VB's with part throttle kickdown.
