Re: OD 833 thoughts?
[Re: 360D100]
#2076909
05/20/16 01:53 AM
05/20/16 01:53 AM
Posts: 25 USA
360D100
USA
[Re: 360D100]
#2076911
05/20/16 01:54 AM
05/20/16 01:54 AM
Posts: 95 NW INDIANA
ta3834bbl
NW INDIANA
Yes, I think it will hold up to some fun. I ran one behind my 383 in a roadrunner.
67 Dart GT Convertible 273 68 Barracuda 383 68 Roadrunner 383 4spd 1 '01 Ram 2500 4x4 diesel 2 '02 Rams 1500 4x4's 4.7s 3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4 Oh, and a 03 Grand Cherokee and an '00 durango
[Re: 360D100]
#2076918
05/20/16 02:12 AM
05/20/16 02:12 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Yes, don't believe the hype that they won't hold up. I know a Guy who's been running one in a 511 Six Pak B-body for years and it's still going strong. I'm beating on two of them at the moment. And, if you wreck it, $100.00 for another and away you go again. Best kept secret in the Mopar world, and that truck you have is a bit of a rare animal (OD small block bellhousing )
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2076942
05/20/16 03:16 AM
05/20/16 03:16 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
They hold up fine as long as you don't run slicks.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: 360D100]
#2079134
05/24/16 12:22 AM
05/24/16 12:22 AM
Posts: 1,511 AZ
Mike P
AZ
".....Yes, don't believe the hype that they won't hold up......" I've got a cracked aluminum case from A833 OD transmissions under the bench and have come across a couple of more cracked ones to prove it's not all hype. That being said I have an iron case A833 OD in my 57 Plymouth that has held up well and I'm not afraid to hammer on. Just my but if it's aluminum it will probably be on borrowed time, an iron case one should be fine.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: 360D100]
#2080108
05/25/16 04:03 PM
05/25/16 04:03 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
What's said above.....I like them....I'm an 833 fan...overdrive or not.
Moparlee
