Hughes performance convertors any good? #2076672
05/19/16 07:13 PM
05/19/16 07:13 PM
Someplace you aren't
SomeCarGuy Offline OP
Going to have to rebuild trans in my diesel. Stock truck, just want better than stock stuff going back in. Hughes sells diesel convertors for about 650 that would appear better than stock, but im sure arent as good as the 12-1300 ones. The stocker lasted 260k, so as long as these arent junk it shoukd be fine.
Never used one in anything, neither have people I know. Anybody run their stuff before?
I want my fair share
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2076751
05/19/16 08:43 PM
05/19/16 08:43 PM
You might want to add this post on the truck forum for better feedback up
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2076842
05/19/16 11:48 PM
05/19/16 11:48 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
bought my triple disc from Dave Goerend even though he only suggested a single disc for my application (towing). That was so long ago I don't even think about my trans in my 01 when I leave town. Had to upgrade the valve body too.
Re: Hughes performance convertors any good? [Re: Cab_Burge] #2076856
05/20/16 12:28 AM
05/20/16 12:28 AM
I dont know, it's for a ford. Just wondering about the company's products in general. I picked up a stalker on here for over 5 years just for saying a ford was fine over in that forum. Not kidding, so couple that with the ones that think the old dodges are worth a ton that dont like me for that, well, im just looking for general info. I have a post on a ford site. Not a whole lot of feedback on the company in general on the web.
So... shruggy
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2076902
05/20/16 01:40 AM
05/20/16 01:40 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I'm surprised you're not finding more on Hughes. They have been around a long time and are sold through Summit so there are probably tons of them out there.
I had one, bought through Summit, which was an 11" 3000 stall for 727. It worked very well, no excessive slip, accelerated nice. I had to change it out when I went to a bigger cam which needed more RPM.
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2076914
05/20/16 01:58 AM
05/20/16 01:58 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I have one of their transmissions in my Charger. Local for me. Nice people, transmission runs great, and they gave me a deal on a "refresh/inspection" when I broke a u-joint. If I ever need a transmission in my Diesel, I would use them.
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2076917
05/20/16 02:11 AM
05/20/16 02:11 AM
Boise
Moparteacher Offline
Boise
I wouldn't bother with an aftermarket converter. It's a stock engine correct? You can have the transmission rebuilder send your tc in and have it rebuilt. As long as the tc rebuilder is using the correct friction material, and knows how to properly adhere it, you should be fine for another 260K.
I would pay close attention to what the transmission rebuilder is doing to extend the life of the transmission.
Which transmission? 4R100, 5R110W, E4OD, or Torqushift?
Year make and model?
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2076939
05/20/16 03:00 AM
05/20/16 03:00 AM
Thanks guys. E40d. 97 f350. Going with the trans go tugger kit for some tweaks to the VB etc while down. The convertor is a total weak link in that trans and im not surprised to be having trouble after pushing it hard with towing in the past year or two.
I run a bigger cooler and syn fluid. Ive had a couple of these trucks and do seem to get ok life from the auto.
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2076974
05/20/16 08:31 AM
05/20/16 08:31 AM
gregsdart Offline
gregsdart  Offline
What about a new Ford part? I am impressed with the vehicles I have from them. An example is the clutch out of my 06 GT. I put a blower on it and at 7psi it makes a ton more grunt, and the stock clutch never gave me a lick of trouble for 50,000 HARD miles with that blower.
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2076981
05/20/16 08:54 AM
05/20/16 08:54 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
There is a company near me called Rev Max. Make a lot of their own products for HD automatic use. I know a lot of guys run their valve bodies and converters for the Dodge diesels. Good prices, too. Might be worth a call to find out about Ford products.
[image][/image]
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2077008
05/20/16 10:15 AM
05/20/16 10:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
So... shruggy
Hughes doesnt make their converters.. it jobbed out..
you really should be talking to converter shops... you
might even look at CTD web site for info... if they
build for a Cummings they would build for any trans
wave
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2077053
05/20/16 11:46 AM
05/20/16 11:46 AM
Thanks for the replies guys
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2077095
05/20/16 01:28 PM
05/20/16 01:28 PM
Boise
Boise
So there are a few converter upgrades for the E4OD. There's a superior clutch plate made by LUK that should be used.It has heavy duty twin dampner springs and more friction material. There are a few modifications to the TCC exhaust hole in the stator body. The exhaust hole should be enlarged to .076-.086". The drain hole for the pump bushing should be enlarged to 5/16". The stator body can be modified for full-time lube as well. This info is probably in the Trans-go kit.
I hope you have a good transmission shop.
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2077114
05/20/16 02:13 PM
05/20/16 02:13 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
Hughes builds their converters in house
Re: Hughes performance convertors any good? [Re: tsanchez] #2077179
05/20/16 04:14 PM
05/20/16 04:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is he talking Hughes engine.. if so they would job it out
wave
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2077193
05/20/16 04:45 PM
05/20/16 04:45 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
two different companies
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2077195
05/20/16 04:48 PM
05/20/16 04:48 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2077199
05/20/16 05:00 PM
05/20/16 05:00 PM
Yes, the ones out west.
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2077259
05/20/16 07:37 PM
05/20/16 07:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My error then... I was thinking the engine place..
I never dealt with the place.. so I no clue
wave
Re: Hughes performance convertors any good? [Re: SomeCarGuy] #2189854
11/05/16 02:32 AM
11/05/16 02:32 AM
This didnt work out. The convertor had a weld pinch the lockup clutch and failed right away. Caused me all sorts of trouble this summer.
Hughes ended up finding the problem. Too bad they didnt want to send me a new one when the shop and I concluded the convertor was junk. They also didnt want to cover the return shipping, neither with a call tag or reimbursing me when they found the issue. I do get all warm and fuzzy when I think about the customer service rep there telling me they normally send a new one to swap, but even though that was one of three, yes three foul ups they committed on this, they still wouldnt do a damn thing for me. He also admitted a call tag should've been sent, but again, that's just my tough luck they dropped the ball on that part and I would get no love on any of this.
I calmly explained i wasnt mad and i understand this sort of thing happens, but for me to take a total, and i mean total loss on this was an obscene injustice. After much pleading on my part, they took a few days and decided they would sell me a convertor at cost(supposedky 200 off) so they wouldnt go out of pocket. Even though they supposedly cover shipping on this sort of thing and werent sure how i got the shaft. I suppose they send out a lot of duds so taking care of me would push the company into bankruptcy.
Worst of all, i got a taste of what the truck should've always been like. The oem stall speed is WAY too high. The convertor was spot on and made the trans feel like myself and others always wanted it to. Problem is, the shop is super busy and when the spot in line came open, it was a rebuilt stocker or nothing. Wish i had just purchased another brand to stick in there, but it snuck up on me and i have had a busy year moving among other things.
Cliff's notes:
So basically if you want a convertor that might be bad OOTB, no part to swap right back in while down to remove their junk, and no return shipping for their junk part, Hughes Performance in AZ can hook you up with all that.
