Frame interchange 1940 Dodge Coupe? #207646
01/29/09 12:49 PM
01/29/09 12:49 PM
Tracy CA
rabid scott Offline OP
"You're Where?"
"You're Where?"
Tracy CA
Like the title says, what year and model frames interchange with a 1940 Dodge two door Coupe?
Not looking for late model type stuff, just what old stuff interchanges.
Re: Frame interchange 1940 Dodge Coupe? [Re: rabid scott] #207647
01/29/09 12:58 PM
01/29/09 12:58 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
just guessing, but I think the 39 is a bit different. 41 should be the same. 46-48 is a bit different too, but might work.
Re: Frame interchange 1940 Dodge Coupe? [Re: RodStRace] #207648
01/29/09 08:17 PM
01/29/09 08:17 PM
Tracy CA
"You're Where?"
"You're Where?"
Tracy CA
I'd like to know for sure, if anyone does know.
I know where a complete 1948 four door Dodge is, just seems like a much bigger car.
Re: Frame interchange 1940 Dodge Coupe? [Re: rabid scott] #207649
01/29/09 10:20 PM
01/29/09 10:20 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
According to the book I have, a 40 Dodge through 48 Dodge lists a 119 1/2" or a 139 1/2" wheel base. By 49, wheel base depended on the body series.
Chrysler lists a 122", 139 1/2", and a 128 1/2" and 145 1/2" wheel bases for 1940.
Desoto lists a 122 and a 139 1/2" wheel base for 1940.
Plymouth lists a 116", (2) 117" and then a few long ones (over 137") for 1940.
So according to the WB you will need a frame from a Dodge only between 1940 and 1948. The 39 Plymouth and the 47 Plymouth we had used the same front and rear suspension. With that in mind, I suspect you would be safe looking for a 119 1/2" wheel base frame from a 40-48 Dodge. Gene
Re: Frame interchange 1940 Dodge Coupe? [Re: rabid scott] #207650
02/01/09 04:55 PM
02/01/09 04:55 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
40 Dodge was the last year with the "X" frame. This generates loads of fun when trying to work driveshafts and exhausts around it. 41 was the first year without the "X." I know the 3 and 5 window D-19 coupes ran the 119 1/2 WB. I think the 2 door sedan may have used the 119 1/2 too, BUT the 4 door was the long one. PM me, as I may have a spare.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: Frame interchange 1940 Dodge Coupe? [Re: RTDaddy] #207651
02/01/09 07:04 PM
02/01/09 07:04 PM
arizona
leavitt4 Offline
leavitt4  Offline
arizona
now for my 1936 dodge will a frame from a 37 coupe fit without alot of modifications cause i think i found a 37 frame relitivly cheap
thanks jason
Re: Frame interchange 1940 Dodge Coupe? [Re: leavitt4] #207652
02/01/09 10:49 PM
02/01/09 10:49 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My book says a 36 Dodge had a 116" and a 128" wheel base while it lists a 37 Dodge as having a 115" and a 132" wheel base. Both were solid axles, front and rear, an inch might not be an issue in a street rod.
35 Dodge lists a 116", a 128" and a 113" wheel base. Gene
Re: Frame interchange 1940 Dodge Coupe? [Re: poorboy] #207653
05/05/09 01:29 AM
05/05/09 01:29 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
i have a 1940 dodge coupe with the stock X frame,, my friend has a 48 dodge coupe no X frame member,, the rails appear to be the same,,the 40 leaf springs bolted right in to the 48 frame,,the 48 had a weird factory rear sway/pan hard type bar,, i could check the wheel base,,but the 48 now has a volare front clip,,e mail me ill get you pics or measurements fstfish66@aol.com
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Frame interchange 1940 Dodge Coupe? [Re: rabid scott] #207654
05/07/09 02:04 AM
05/07/09 02:04 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
There are like 3 1940-41 2dr dodges listed on craigslist here in CA. Maybe there is one worth looking at if the price is right.
