Re: Nice thick undercoating like the factory tar stuff?
[Re: Adam71Charger]
#2075740
05/18/16 11:45 AM
05/18/16 11:45 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Resto Rick sells a product that is like the factory stuff.
[Re: Adam71Charger]
#2075897
05/18/16 03:31 PM
05/18/16 03:31 PM
Posts: 2,592 None
71rm23
None
It's not the ingredients I'm trying to match, it's the thickness and adhesion I'm after. Of course, I'd like it to look like an automotive undercoating, but I don't need the actual stuff they used. John I'll check out restore rick thanks. Jcc, I swear they used to put asbestos in everything lol.
I would like to know though, what the stuff they used in the 70's was made of and how it was applied. My guess is its similar to asphalt and was applied hot? I've always heard and knew that every factory did things differently. I don't know if there was a "standard" as for undercoating. With that, the majority of people claim undercoating was mainly left for the dealerships to apply but not always
[Re: Adam71Charger]
#2075999
05/18/16 06:16 PM
05/18/16 06:16 PM
JohnRR
U.S.S.A.
check with Rick , he has stuff that acts similar and the gun to apply it , it won't be cheap though . If it's not a restoration something like herculiner would work well. I bought some bedliner that came in a spray can ...
[Re: Adam71Charger]
#2076113
05/18/16 09:18 PM
05/18/16 09:18 PM
Posts: 1,457 oklahoma
forphorty
oklahoma
I've used spray undercoating before, but it was a lot thinner than the 'tar-like' factory undercoating. What is a decent undercoating that can be applied 1/4" thick and stick well to both bare and painted metal? I wouldn't put undercoating over bare metal. If it gets moisture underneath it will rust like crazy. I'm not a real fan of undercoating myself (except in the wheelhouse). You might check this out:http://3mcollision.com/3m-body-schutz-rubberized-coating-black-8864.html
[Re: Adam71Charger]
#2076115
05/18/16 09:25 PM
05/18/16 09:25 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I used to use roofing tar mixed with gasoline (grew up in the rust belt), the gasoline would evaporate and I applied it with a suction sand blaster...worked good, last a life time. The cars would rot around the tar...Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Adam71Charger]
#2076182
05/18/16 11:18 PM
05/18/16 11:18 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
RestoRicks stuff works well for me, but bear in mind, how you apply it (air pressure, speed, flash time etc.) will greatly affect the overall appearance. This is a good thing though as it allows you some flexibility in tailoring the look you're after.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: Adam71Charger]
#2076273
05/19/16 01:09 AM
05/19/16 01:09 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Any coating in a can and a... and here's the key, a schultz gun.
When it takes more than a sweet mullet to prove you rule at the trailer park..
