Can you figure out what was wrong with my Transmission? #2074575
05/16/16 04:00 PM
05/16/16 04:00 PM
ky.
K
kenworth_goose Offline OP
K
ky.
I have a 92 Dodge Dakota, 5.2, 46rh transmission. First thing started was the lockup was in and out of lockup probably 2-3 times per second. So I cut the lockup wire from the Pcm to eliminate that problem. All was good for 4-5 days then it came back, all the while the wire is still cut. Then overdrive started doing the same thing. So I cut the overdrive wire from The pcm as well. So now I have no power to the lockup or overdrive. Fine for a day. Guess what? It started doing it again. I finally figured it out And all is fixed and repaired and working well. But I don't think ANYONE will be able to guess correctly what caused the issue.
Re: Can you figure out what was wrong with my Transmission? [Re: kenworth_goose] #2074591
05/16/16 04:34 PM
05/16/16 04:34 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
pressure switch----on-off value dies causes the flutter..
Re: Can you figure out what was wrong with my Transmission? [Re: kenworth_goose] #2074597
05/16/16 04:54 PM
05/16/16 04:54 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Don't tell us it was a just a plug or plug wire....
Re: Can you figure out what was wrong with my Transmission? [Re: kenworth_goose] #2074604
05/16/16 05:00 PM
05/16/16 05:00 PM
ky.
K
K
ky.
Nope
Re: Can you figure out what was wrong with my Transmission? [Re: kenworth_goose] #2074624
05/16/16 05:43 PM
05/16/16 05:43 PM
scratchnfotraction Offline
TPS sensor?
Re: Can you figure out what was wrong with my Transmission? [Re: kenworth_goose] #2074637
05/16/16 06:02 PM
05/16/16 06:02 PM
ky.
K
K
ky.
nope
Re: Can you figure out what was wrong with my Transmission? [Re: kenworth_goose] #2074680
05/16/16 07:23 PM
05/16/16 07:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Operator trouble?
Re: Can you figure out what was wrong with my Transmission? [Re: stumpy] #2074772
05/16/16 10:23 PM
05/16/16 10:23 PM
ky.
K
K
ky.
Originally Posted By stumpy
Operator trouble?
NOT!
Re: Can you figure out what was wrong with my Transmission? [Re: kenworth_goose] #2074780
05/16/16 10:32 PM
05/16/16 10:32 PM
ky.
K
K
ky.
Okay, I'll let you in on it. If you are familiar with these Dakota's and the wiring over by the battery then you have seen the white and black cables that run off of the positive cable. Well it was the black connector that was corroded inside the pieces that slide together. I finally got tired of having trouble and I started pulled and twisted on any wires I could get my hands on. When I moved the black cable It started running better. So I half way cleaned it and then went for a ride and no more issues. So the next day at work I had some free time so I cut the connectors out and soldered 2 copper lugs on the cables and bolted them together. Nooooo more issues. Seems I was loosing the power to the inside of the truck. And thinking about the past one day my stereo flickered. I recently broke down, the coil burned up. I think they are connected.
Re: Can you figure out what was wrong with my Transmission? [Re: kenworth_goose] #2075338
05/17/16 08:42 PM
05/17/16 08:42 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Wait wait wait before I read the answer.... loose nut behind the wheel???
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
