75 D100 - How do you mount the spare tire? #2073642
05/15/16 12:31 AM
05/15/16 12:31 AM
Sacramento, CA
E
ESP47 Offline OP
ESP47  Offline OP
E
Sacramento, CA
I have the bracket
http://www.dodgeconnection.com/catalog/item/2901766/6284873.htm
J Bolt
http://www.dodgeconnection.com/catalog/item/2901766/6284877.htm
and J Bolt nut
http://www.dodgeconnection.com/catalog/item/2901766/6284881.htm
On the side of the bracket with the single hole, I have a bolt running up to the frame that is fixed and attached.
On the opposite end there are two holes. The oblong hole that is closer to the middle is on about a 45* bend on the bracket. I have the J bolt hooked into the frame and the thread runs down through the hole. I take the J bolt nut and start to screw it onto the J bolt. Only problem is that once it gets semi close to the bracket, the J bolt nut wont turn any longer because it contacts the sides of the spare tire bracket. It just won't thread on far enough to get tight.
I'm frustrated as hell and I cannot for the life of me figure it out. I've never use hardware like that nut and I've never seen one installed, nor can I even find a picture of one installed. Does anyone have an idiots guide for how to properly cinch up the spare tire to the bottom of the bed? Thanks.
Re: 75 D100 - How do you mount the spare tire? [Re: ESP47] #2073654
05/15/16 12:59 AM
05/15/16 12:59 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The J bolt comes down through the end hole on the same end as the oval hole. With the mushroom end of the nut going up against the bracket.
Re: 75 D100 - How do you mount the spare tire? [Re: ESP47] #2073820
05/15/16 01:15 PM
05/15/16 01:15 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Are you putting the J bolt through the flat end or channel end?? There are three holes so your description of "the hole" is a little vague.
The J bolt goes through the outermost hole on the flat end of the mount
If it still wont tighten sufficiently shorten the fixed end of the carrier.
As an additional precaution place a cable around the spare and chassis, its not un-common to get to where your going and find a missing spare...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 75 D100 - How do you mount the spare tire? [Re: ESP47] #2073848
05/15/16 02:20 PM
05/15/16 02:20 PM
Guitar Jones Offline
You might want to at least buy it some flowers first.
Re: 75 D100 - How do you mount the spare tire? [Re: ESP47] #2074741
05/16/16 09:38 PM
05/16/16 09:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Well?
Re: 75 D100 - How do you mount the spare tire? [Re: ESP47] #2074769
05/16/16 10:20 PM
05/16/16 10:20 PM
Sacramento, CA
E
ESP47 Offline OP
ESP47  Offline OP
E
Sacramento, CA
Thanks for the replies fellas. I was putting the bolt through the wrong hole in the bracket because the hole in the frame that's closest to the real bumper just wasn't quite big enough to slip the J bolt through. I was figuring it just wasn't meant to go in that spot. I drilled it out just a tad and it went in.
After tightening the J bolt nut up, I noticed that the J bolt itself hung down 4-5" lower than the rear bumper and just looked bad so I ended up using a shorter bolt so you can't really see it hanging down. I'll either cut the J bolt or find a shorter one so less tools are required to remove the tire in case of a flat.
Re: 75 D100 - How do you mount the spare tire? [Re: ESP47] #2076287
05/19/16 01:45 AM
05/19/16 01:45 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I used "C"-channel bolted to the stake pockets, and stood the tires up in the bed, then bolted them to the "C"-channel.
Not exactly what you were looking for however...
It does kinda answer the, "How do you mount the spare tire?" question.
smile
I have mechanical Aptitude.
I can screw up anything.
