75 D100 - How do you mount the spare tire?
#2073642
05/15/16 12:31 AM
05/15/16 12:31 AM
Posts: 59 Sacramento, CA
ESP47
Sacramento, CA
I have the bracket http://www.dodgeconnection.com/catalog/item/2901766/6284873.htmJ Bolt http://www.dodgeconnection.com/catalog/item/2901766/6284877.htmand J Bolt nut http://www.dodgeconnection.com/catalog/item/2901766/6284881.htmOn the side of the bracket with the single hole, I have a bolt running up to the frame that is fixed and attached. On the opposite end there are two holes. The oblong hole that is closer to the middle is on about a 45* bend on the bracket. I have the J bolt hooked into the frame and the thread runs down through the hole. I take the J bolt nut and start to screw it onto the J bolt. Only problem is that once it gets semi close to the bracket, the J bolt nut wont turn any longer because it contacts the sides of the spare tire bracket. It just won't thread on far enough to get tight. I'm frustrated as hell and I cannot for the life of me figure it out. I've never use hardware like that nut and I've never seen one installed, nor can I even find a picture of one installed. Does anyone have an idiots guide for how to properly cinch up the spare tire to the bottom of the bed? Thanks.
Re: 75 D100 - How do you mount the spare tire?
[Re: ESP47]
#2073820
05/15/16 01:15 PM
05/15/16 01:15 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Are you putting the J bolt through the flat end or channel end?? There are three holes so your description of "the hole" is a little vague. The J bolt goes through the outermost hole on the flat end of the mount If it still wont tighten sufficiently shorten the fixed end of the carrier. As an additional precaution place a cable around the spare and chassis, its not un-common to get to where your going and find a missing spare...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: ESP47]
#2073848
05/15/16 02:20 PM
05/15/16 02:20 PM
Guitar Jones
You might want to at least buy it some flowers first.
[Re: ESP47]
#2076287
05/19/16 01:45 AM
05/19/16 01:45 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I used "C"-channel bolted to the stake pockets, and stood the tires up in the bed, then bolted them to the "C"-channel. Not exactly what you were looking for however... It does kinda answer the, "How do you mount the spare tire?" question.
I have mechanical Aptitude. I can screw up anything.
