Re: EXHAUST CUTOUTS
[Re: magic1]
#2074110
05/15/16 09:18 PM
05/15/16 09:18 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
DUDE HOW MANY TIMES YOU GONNA ASK IT AND FIX YOUR CAPS LOCK
Re: EXHAUST CUTOUTS
[Re: magic1]
#2074188
05/15/16 10:35 PM
05/15/16 10:35 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I just looked at Magic1's list of posts and I don't see where he's asked this question before. Maybe I missed it.
I love my DMH 3" electric cutouts, the kit comes with everything you need and they are good quality, plus he stands behind them as long as you don't smash them against the pavement.
Re: EXHAUST CUTOUTS
[Re: SNK-EYZ]
#2074349
05/16/16 04:23 AM
05/16/16 04:23 AM
RapidRobert
Magic you can post all you want. I would suggest vac controlled cutouts in conjunction with a restricted (quiet) ex system. that way you are in stealth mode & when you nail it, it'll all be over in ten seconds & all you have to do is go collect the money from the (neutral) third party. they'll never know what hit em! If you have a 3" system rearward you will need to get creative in order to keep it to a reasonable roar (if desired). just me I would do a 3" or 3.5" cutout (whatever your collector dia is) for max horsepower/fear factor right there at the collector flange then T from it into a quiet system (2.5" with restricted (quiet) muffs) rearward. that way you dont have to mess with pulling (2) cables as your undivided attention is needed elsewhere
Re: EXHAUST CUTOUTS
[Re: GoodysGotaCuda]
#2074387
05/16/16 09:45 AM
05/16/16 09:45 AM
Posts: 10,167 A Red State
SNK-EYZ
A Red State
How long have you had them? I believe it's 3 years now that they've been on my car. ![work work](/ubbthreads/images/graemlins/custom/work.gif)
Re: EXHAUST CUTOUTS
[Re: magic1]
#2077855
05/21/16 08:52 PM
05/21/16 08:52 PM
Posts: 1,800 South Lyon MI
sleddinfool
South Lyon MI
I have the jegs ones on my 71 gtx $189.00-$289.00? They are the electric one and have been on my car for a year. You can hear them kind of rattle like as some exhaust does escape them. The rest of the exhaust is 3" all the way back. Only take a second to open them and car sounds great. They dump right under the doors. Kevin
71 gtx.....
Re: EXHAUST CUTOUTS
[Re: magic1]
#2078008
05/21/16 11:48 PM
05/21/16 11:48 PM
Posts: 5,447 So Cal
Sinitro
So Cal
I have an original set of the Dougs.. Been on the RoadRunner for 10 years, they work well no leaks like the QTP butteryfly type. I would recommend when mounting weld a small side support bracket because they are bulky.. Also I replaced the Chinese sourced DPDT toggle switch with a mil-spec Cutler/Hammer switch better feel and more reliable... Just my $0.02... ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
Re: EXHAUST CUTOUTS
[Re: magic1]
#2078182
05/22/16 12:07 PM
05/22/16 12:07 PM
Posts: 12,294 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have had several different sets of electric cut-outs on my cars over the years. Every set of butterfly cut-outs I have seen, leak. I have an older set of the Doug's on the Cuda now. They were expensive and are bulky. But they have taken a beating and still don't leak. Is it true that Doug's changed their design and no longer make that guillotine or sliding style?
Electric cut-outs are a blast. I use them more around car shows and cruises than at the track. I'll never have another muscle car without them.
Master, again and still
