where to get 3/8 fuel line #207419
01/29/09 12:12 AM
01/29/09 12:12 AM
ERIE PA home of the RENCH MOB
mike_vango Offline OP
i need to upgrade to 3/8 line in my 74 swinger. just need to know the best place/best price. doesn't need to be stainless. i'd like to paypal them. thanks
Re: where to get 3/8 fuel line [Re: mike_vango] #207420
01/29/09 12:20 AM
01/29/09 12:20 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I'm not sure where you should buy it, BUT if I were you, I'd get aluminum, instead of steel.
WAY easier to work with.
Re: where to get 3/8 fuel line [Re: dave571] #207421
01/29/09 12:27 AM
01/29/09 12:27 AM
i was thinking of getting the pre bent line. i'm afraid if i bent it up myself it would kink on the bends.
Re: where to get 3/8 fuel line [Re: mike_vango] #207422
01/29/09 12:32 AM
01/29/09 12:32 AM
dave571 Offline
dave571  Offline
OK. That's a little different
If you do go with something you make yourself, the aluminum stuff is so soft, you can bend it by hand,(no tool required) and it won't kink.
There are a few benefits to running your own. You can route it so you don't get ase many bends, etc. and obviously cost. $30 or so will do the whole job.
Re: where to get 3/8 fuel line [Re: dave571] #207423
01/29/09 01:38 AM
01/29/09 01:38 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: where to get 3/8 fuel line [Re: megajoltman] #207424
01/29/09 02:01 AM
01/29/09 02:01 AM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Re: where to get 3/8 fuel line [Re: Fab64] #207425
01/29/09 02:52 AM
01/29/09 02:52 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I bought mine from Jegs. Aluminum CAN be kinked, if you bend it too sharp, but it's soft enough that you can bend it by hand, take your time, and avoid kinks.
a trick when you want to make it as straight as possible when un-coiling it from the box, is to lay it on the floor and take a long wide board, maybe a 2x12 or even a piece of plywood, and use that to roll it out. it's the same theory as using a long board for sanding your car.
go slow, take your time, and it'll come out geat!
and alunimum doesnt rust!
**Photobucket sucks**
Re: where to get 3/8 fuel line [Re: mike_vango] #207426
01/29/09 08:10 AM
01/29/09 08:10 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what's the reason for the upgrade? Do you have a 3/8 sending unit? if you don't a 3/8 line won't be worth much. Unless you have a mid 11 second car there is really no need to jump to 3/8. The problem I had w/ finelines is the ship the line bent in half...so you have to straighten it and it's not as easy nor will it ever be as straight as it should be. If you can wait and pick one up at a show or MOPAR event you won't have to have it shipped bent in half.
Re: where to get 3/8 fuel line [Re: Mr.Yuck] #207427
01/29/09 08:16 AM
01/29/09 08:16 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
I have fine lines and they went in nice. You have straighten them but they put a peice of tape indicating where the bend should be straightened. I have the stainless 3/8 for a 69 roadrunner and I like the fit and look. I thought installation was pretty easy. I was restoring my car though so there wasn't too much in the way. Although I dont think it would have been that much harder.
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: where to get 3/8 fuel line [Re: moepwr] #207428
01/29/09 09:37 AM
01/29/09 09:37 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Once you bend the tube the metal distorts...It does have the tape but the line will never be nice and straight again. I did install pretty easy but I had to fudge it at the bend more than a few times..even after I thought it was straight.
Re: where to get 3/8 fuel line [Re: Mr.Yuck] #207429
01/29/09 10:22 AM
01/29/09 10:22 AM
i got the 3/8 sending unit already installed.
i will check the links above. thanks
Re: where to get 3/8 fuel line [Re: mike_vango] #207430
01/29/09 10:29 AM
01/29/09 10:29 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Napa has a 25'steel roll for about $25 if you want to bend it yourself.
Re: where to get 3/8 fuel line [Re: 446acuda] #207431
01/29/09 12:21 PM
01/29/09 12:21 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I second the suggesation of using a coli of aluminum tubing (from Summit, Jeg's, etc.). Using a coiled tubing bender ($3.00 at your local Ace Hardware store) you can make kink free bends wherever you need to, and get a custom fit along the tubing's entire length. You'll need a flaring kit, too, but it's easy to flare aluminum after a bit of practice.
Re: where to get 3/8 fuel line [Re: In_The_Pink] #207432
01/29/09 02:06 PM
01/29/09 02:06 PM
i think this is what i'll do. i have the flaring kit with the coil bendy thing. thanks
