Brake lines, calibers or both on 2500 #2074116
05/15/16 09:25 PM
05/15/16 09:25 PM
Petersburg, Va
Darrell Offline OP
Darrell  Offline OP
Petersburg, Va
Have a 2002 2500 2wd with the ctd that i bought new with 78000 miles on it now. Last week I was bringing a load of dirt home and got caught in traffic where i had to stop and go every 10 feet for about a mile or better. When we got turned loose my right front brake was holding but let loose after a mile down the road. Ive drove it around my house and cant make it lock up again. Brake hoses, calibers, or just replace them all?
Re: Brake lines, calibers or both on 2500 [Re: Darrell] #2074125
05/15/16 09:34 PM
05/15/16 09:34 PM
Central NY
GarageDodge Online content
GarageDodge  Online Content
Central NY
brake hose.
Re: Brake lines, calibers or both on 2500 [Re: Darrell] #2075336
05/17/16 08:40 PM
05/17/16 08:40 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
BTW... its Calipers...not calibers
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Brake lines, calibers or both on 2500 [Re: W.I.N. Racing] #2076097
05/18/16 08:55 PM
05/18/16 08:55 PM
IN
ahy Offline
ahy  Offline
IN
If you can get it to lock up again see if loosening the bleeder releases it. If so, and since it is one side only, probably a collapsing hoses as mentioned.
Re: Brake lines, calibers or both on 2500 [Re: W.I.N. Racing] #2076812
05/19/16 10:50 PM
05/19/16 10:50 PM
Petersburg, Va
Darrell Offline OP
Darrell  Offline OP
Petersburg, Va
Sorry but down here in the south we call them calibers. LOL
Thanks guys, I am debating on replace everything or just the hoses. So far it is doing fine and I have new hoses to put on, just wondering if I should do it all
Re: Brake lines, calibers or both on 2500 [Re: Darrell] #2077013
05/20/16 10:33 AM
05/20/16 10:33 AM
IN
ahy Offline
ahy  Offline
IN
It is likely a collapsing hose... but you could also have a sticking caliper. Personally I would do both to avoid possible repeat service. Since it is one side only, that pretty much rules out the master.
