FINALLY got me a 360..
#2074113
05/15/16 09:20 PM
05/15/16 09:20 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
.. I had to pull it, $50. Lol. Now lets see how much horsepower that stock block can handle. Ok seriously though, after working 20 years with big blocks, this will be my first serious N/A small block build. please excuse the noob questions.. This is a run of the mill 74 360, no windage tray, etc. Is there enough meat on the block for a 4-bolt main conversion (if even available)? Or would it make that area weaker on a stock block? Is a stock mains and stud kit plenty for say 6500-6700 rpm (will be a 4" stroke crank)? I'm sure I'll have more questions later on, thanks. And got this for 10 bucks, cause nothing short of a dominator will do but that's way down the road.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: FINALLY got me a 360..
[Re: DARTH V8Я]
#2074121
05/15/16 09:29 PM
05/15/16 09:29 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I wouldn't do a four bolt main, weakens block. I ran stock 340 blocks harder then that with arp studs. I would also do a short fill to give it a little more stability.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: DARTH V8Я]
#2074128
05/15/16 09:36 PM
05/15/16 09:36 PM
Posts: 4,457 Washington
madscientist
Washington
There are guys who put 4 bolt caps on Pcar blocks but it is a waste of time and WILL make the block weaker.
BTW with that stroke and those mains, I would have no less that .0036-.0038 main clearance. The block will flex and eat up the clearance.
[Re: DARTH V8Я]
#2074190
05/15/16 10:39 PM
05/15/16 10:39 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Not sure how fast you are lookin to go but I beat the snot out of a stock stroke iron headed truck 360 w/a clean up and GOOD valve job from Pettis, a solid Isky flat tappet cam and it went 11.80`s at L.A.C.R`s altitude track and was my daily driver............not stellar but fun..........
[Re: madscientist]
#2074222
05/15/16 11:23 PM
05/15/16 11:23 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
BTW with that stroke and those mains, I would have no less that .0036-.0038 main clearance. The block will flex and eat up the clearance. Not only the mains, mine was flexing enough the cam bearings had grooves in them.
[Re: DARTH V8Я]
#2074228
05/15/16 11:32 PM
05/15/16 11:32 PM
Posts: 13,194 aZLiViN
J_BODY
aZLiViN
sheesh! we went from R blocks and Ritter blocks to this??? at least we know you are sane now!! We had a nice 340 block build that went a best of 9.8's. Only had a roll bar so my dad was shifting at like 5800 with a 4.3 gear. Bumped it up to 6800 it really got with it... I'm betting more gear and some tuning we would have been able to get some 9.6's out of it.... unfortunately it met a leaky W5 untimely death. If those heads would have been worth a krap I'm betting we'd still be wheeling that mill. 4" stroke, 2 bolt main, 13.5 to 1 compression, Indy intake with 4500 adapter. life was so much simpler then.....
[Re: J_BODY]
#2074284
05/16/16 01:05 AM
05/16/16 01:05 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Looks it a fun build. Im in the process of building one myself for my sister... Eagle rods K1 crank SRP Pistons 4in stroke. Solid flat tappet and Edelbrock heads. I ran a 408 built on a 1999 block with 360-1 . It was a 2 bolt Main...man put a ton of passes on thing.good luck
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: DARTH V8Я]
#2074329
05/16/16 02:51 AM
05/16/16 02:51 AM
DARTH V8Я
Its a TRAP!
@ Thumperdart - looking for high 9's @ 3100#. Going tomorrow to buy a used 1050 Dominator, will be sending it to you when I'm ready @ 1967dartgt & madscientest - roger that, no 4-bolt mains. ARP mains studs on stock or aftermarket caps? @ J-Body R's are out there, but suddenly the prices went Sky High, guess cause now when they are no longer being produced. Talked with a few people about the Ritter block, machine costs alone would be quadruple to a very well machined/prepped stock block. So had to go with plan 'c'.. the 50 dollar engine lol. Indy 360-1's are still the plan. Now the short fill question. Necessary for a street driven engine that'll only see the track twice a year @ the ET i'm gunning for? I'm not fond of filled blocks, however if it makes it more stable, I guess I'll have to be open to the idea. @ whitedart good to know the 2-bolt mains held up, thanks.
[Re: DARTH V8Я]
#2074330
05/16/16 02:58 AM
05/16/16 02:58 AM
madscientist
Washington
Studs and a short fill. Good to go.
[Re: DARTH V8Я]
#2074477
05/16/16 12:56 PM
05/16/16 12:56 PM
Thumperdart
State of confusion
@ Thumperdart - looking for high 9's @ 3100#. Going tomorrow to buy a used 1050 Dominator, will be sending it to you when I'm ready @ 1967dartgt & madscientest - roger that, no 4-bolt mains. ARP mains studs on stock or aftermarket caps? @ J-Body R's are out there, but suddenly the prices went Sky High, guess cause now when they are no longer being produced. Talked with a few people about the Ritter block, machine costs alone would be quadruple to a very well machined/prepped stock block. So had to go with plan 'c'.. the 50 dollar engine lol. Indy 360-1's are still the plan. Now the short fill question. Necessary for a street driven engine that'll only see the track twice a year @ the ET i'm gunning for? I'm not fond of filled blocks, however if it makes it more stable, I guess I'll have to be open to the idea. @ whitedart good to know the 2-bolt mains held up, thanks. Oh, more smallblocks whoopin on big blocks...........I get it.......... I`ve got blocks, boosters and bowls lookin for a good home............
[Re: qwkmopardan]
#2074594
05/16/16 04:38 PM
05/16/16 04:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Can you tell me the specs on the STX22.. I couldnt find them on line.... I'm looking to change cams... thanks
[Re: DARTH V8Я]
#2074600
05/16/16 04:54 PM
05/16/16 04:54 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
STX-21M 306 272@.050 .560 .597
[Re: krautrock]
#2074609
05/16/16 05:11 PM
05/16/16 05:11 PM
MR_P_BODY
Thanks..... what LSA are the STX22 ground on.. and I assume its a solid FT cam
[Re: MR_P_BODY]
#2074859
05/17/16 12:08 AM
05/17/16 12:08 AM
madscientist
Washington
Thanks..... what LSA are the STX22 ground on.. and I assume its a solid FT cam Jim will pretty much grind his lobes on the LSA you want. He also has lobes not on that web site. You just have to call him. I'm using a lobe not on Dons site.
[Re: DARTH V8Я]
#2074876
05/17/16 12:48 AM
05/17/16 12:48 AM
DARTH V8Я
Its a TRAP!
@ qwkmopardan ~ thanks for the info. Didn't think those "smogger" heads had enough flow for a 9 second pass. Nice combo BTW. @ thumperdart you bet buddy :thumb: & duly noted expect a package later on Solid rollers question: I know they are spendy, but PITA to install & clearance or pretty straight forward? Thanks.
