What is new in B-body transmission swaps and overdrives?
#2074101
05/15/16 09:03 PM
05/15/16 09:03 PM
Posts: 78 AZ
2ndopp
AZ
Dropping freeway rpms seems to be a critical part of bringing our cars up to date. My 73' Plymouth satellite currently has a strong 727 with 3.73 gears in the back. I plan on bumping up to 4.10 eventually, but not before I take car of the transmission. I thought I wanted to go with the gear vendors bolt on overdrive, but then I found out about the A-518 swap. These are great choices, but since it's 2016, I was wondering what new options we have for swaps. Are there any modern 5 or 6-speed automatics that can be installed with minimal fabrication? Here are the options I know about: Gear Vendors 727 bolt on overdrives: 3-speed plus overdrive (.78) https://www.gearvendors.com/hrdodge3s.htmlMinimal fitting adjustments, driveshaft lengthening 4.10 gears drive like 3.20 A-518 transmission swap 3-speed plus overdrive (.69) http://www.cuda-challenger.com/cc/index.php?topic=84774.0Major alterations to fit, new cross member. 4.10 gears drive like 2.83 Keisler A41 transmission swap Discontinued?3-speed plus overdrive (.70) Electronically controlled http://www.hotrod.com/how-to/transmission-drivetrain/0908phr-keisler-a41-automatic-transmission/Minimal fitting adjustments, driveshaft lengthening 4.10 drives like 2.87
Re: What is new in B-body transmission swaps and overdrives?
[Re: 2ndopp]
#2074343
05/16/16 03:49 AM
05/16/16 03:49 AM
Posts: 4,732 Florida
BDW
I went with the 518 in my SB Challenger and love it. I definitely wouldn't say it was major modifications. It was the least expensive option. I have 3.73 gears and the OD has made the car so I don't mind taking it on 2-3hr road trips.
[Re: 2ndopp]
#2074544
05/16/16 02:52 PM
05/16/16 02:52 PM
Posts: 75,035 U.S.S.A.
JohnRR
U.S.S.A.
Pictures of this INSTALLED???
Kiesler was great for a NO CUTTING required install that made a mess of the factory driveline angle because many Mopar owners refuse to cut anything ...
[Re: JohnRR]
#2074800
05/16/16 11:02 PM
05/16/16 11:02 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Kiesler was great for a NO CUTTING required install that made a mess of the factory driveline angle because many Mopar owners refuse to cut anything ... John, I think your confusing the Tremec TKO 5 spd MANUAL withe the 4spd AOD (A41), I've done the 4spd AOD (A41) in a 71 B body with NO mods to the floor, driveline angles were within factory specs, the 4spd AOD is no larger than the TF727, the 4spd AOD (A41) was truly a "bolt-in" kit application
[Re: 2ndopp]
#2074880
05/17/16 12:51 AM
05/17/16 12:51 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
A41 kit is nice, real nice.. but spendy. I'll second the 200R4 route.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: 2ndopp]
#2075023
05/17/16 11:29 AM
05/17/16 11:29 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Still only small blocks right? Any big block automatic affordable overdrive options?
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#2075498
05/18/16 12:45 AM
05/18/16 12:45 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Still only small blocks right? Any big block automatic affordable overdrive options? The Silver Sport transmission is available with either a small block or a big block bell housing. The transmissions they use have a bolt on bells. All the other options, Mopar 500/518, GM 2004R or the 700R4 would have to have their original bell cut off and have a JW ultra Bell bolted on.
[Re: DAYCLONA]
#2075575
05/18/16 01:57 AM
05/18/16 01:57 AM
JohnRR
U.S.S.A.
Kiesler was great for a NO CUTTING required install that made a mess of the factory driveline angle because many Mopar owners refuse to cut anything ... John, I think your confusing the Tremec TKO 5 spd MANUAL withe the 4spd AOD (A41), I've done the 4spd AOD (A41) in a 71 B body with NO mods to the floor, driveline angles were within factory specs, the 4spd AOD is no larger than the TF727, the 4spd AOD (A41) was truly a "bolt-in" kit application Thanks Mike , I don't know much about that auto trans and whenever I see something that came from Kiesler and had a NO HACK FIT I'm VERY SKEPTICAL after seeing a car with a Kiesler T5 and the bottom of the stock fan blade almost touching the radiator.
[Re: 2ndopp]
#2084492
06/02/16 08:06 AM
06/02/16 08:06 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Installed an A500 in my '72 Charger five years ago. It is great behind a late model 360 magnum. Put 1300 miles on it in one trip.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: 2ndopp]
#2085548
06/03/16 09:52 PM
06/03/16 09:52 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I drove a B-Body with a Gear Vendors. It was too little of a difference in gearing for the $, and a bother to use compared to what I have now.
I ended up using a 200R4 in my A-Body. While not cheap, the gear ratios are as close to perfect as you could get. Combined with the lock-up feature, it's like having a 5 speed automatic. Heck, I beat a Hellcat in a flag drop drag race over 300 miles from home. Next to EFI, it's one of the greatest upgrades you can do to these older Mopars.
US Cartool makes a kit to swap the transmission in, and Lonnie at Extreme Automatics can set up a 200R4 to hold over 1000 hp and it will bolt up to any Mopar engine out there including the GenIII Hemi's with the exception of the Slant 6.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 2ndopp]
#2085565
06/03/16 10:10 PM
06/03/16 10:10 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Thats the one i have in the road runner now. Work pretty darn nice!! I have 373's in the back and i am spinning 2000RPM at 65MPH or at least as close as my in dash tach says.
[Re: jbc426]
#2085653
06/04/16 12:36 AM
06/04/16 12:36 AM
Kern Dog
Granite Bay CA
US Cartool makes a kit to swap the transmission in, and Lonnie at Extreme Automatics can set up a 200R4 to hold over 1000 hp and it will bolt up to any Mopar engine out there including the GenIII Hemi's with the exception of the Slant 6. Ok, I am interested.
