Page 4 of 4 1 2 3 4
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073011
05/14/16 12:50 AM
05/14/16 12:50 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Originally Posted By Wookie316
610/565 with 750. 630/580 with 950. More details later. Off to the races now.
Do I win? I was 8 hp and 4 ft lbs off
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073033
05/14/16 01:26 AM
05/14/16 01:26 AM
Springs hold to 7000. Obviously my local machine shop is a little rough with the bore though according to the vac readings. Drops off bad at 7200 and its still making power. Guess you get what you pay for. Torque plates work laugh
On another note, tech'd and waiting to race.
Is the dnyo your using a chassis or engine dyno? If a engine dyno your parts are way over achieving IMO, if on a chassis dyno your really making me jealous now bow up
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073038
05/14/16 01:30 AM
05/14/16 01:30 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Yes. They said pan evac Not good enough. What's the best vac pump to buy? Where do they fit if your running a p/s pump for the hydra steer?
Air pump off a V6 GM truck 99-03 I've run one for years. They don't make much power but they do provide evac. If you go with a mechanical pump I would look at Star or GZ.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073150
05/14/16 11:29 AM
05/14/16 11:29 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As for the question of a vacuum pump. Here is my .02. Get a Moroso three vane, good pumps and will not require a relief valve. It wont make enough to get to the point of pulling to much vacuum and will provide enough to be a benfit.
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073153
05/14/16 11:32 AM
05/14/16 11:32 AM
Muncie
Racebuddy Offline
Racebuddy  Offline
Muncie
I think 650 hp would be an achievable number. Air flow aint poo for hp estimations. nice motor, glad to see the Big blocks doing well
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073239
05/14/16 01:32 PM
05/14/16 01:32 PM
Alberta
Wookie316 Offline OP
Alberta
Castrol May 13 2016 1971 Superbee
First time out with the new combo, 10.90 bests, 123MPH & 1.54 60 foot. Not bad for 4000 + pounds.
I can put more timing in it and leave harder on the brake yet. So room to grow!
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073243
05/14/16 01:37 PM
05/14/16 01:37 PM
CA
crackedback Offline
crackedback  Offline
CA
Nice ride!!!
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073254
05/14/16 01:53 PM
05/14/16 01:53 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Damn fast for a street beast. Real nice looking, too.
[image][/image]
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073290
05/14/16 03:02 PM
05/14/16 03:02 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Let me make sure that I'm clear on this... you went from the engine dyno to installing the engine in the car to testing the car at the track ON THE SAME DAY?
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073304
05/14/16 03:25 PM
05/14/16 03:25 PM
Alberta
Alberta
No. 2 engines. Have a 511 low deck in the car now.
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073535
05/14/16 10:03 PM
05/14/16 10:03 PM
so the stock stroke motor was on a engine dyno, yes? If you don't mind my prying what brand dyno and are these results corrected to ASE instrument standard conditions or are they uncorrected results ? confused
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073647
05/15/16 12:40 AM
05/15/16 12:40 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Awesome car! My dad tells me stories about a super bee my cousin had in the same color combo that ran from the cops a few times and would do nasty donuts.
I bet you surprise a lot of people in that beast. They may see the tires and think twice but that's it.
Re: Place your bets, Dyno scheduled this Friday [Re: BradH] #2073660
05/15/16 01:12 AM
05/15/16 01:12 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Good catch Brad. Wookie, what the heck!! Didn't you think that we would all think the First time out times were a reflection of the new Dyno,ed motor??
Whats the build specs and HP of the AS run 511?
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073676
05/15/16 02:00 AM
05/15/16 02:00 AM
Alberta
Alberta
Engine build details here.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2057137
http://amsengines.com
Their new website is still under construction. I'm not 100% sure what their Dyno is but I know it is corrected.
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073772
05/15/16 11:18 AM
05/15/16 11:18 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Ok, yes I remember that very nice build. You have two great running engines.
Might of been a little less confusing if you put the new track results in the matching engine build thread with its 750 hp numbers and such. But no biggie, I think its clarified now.
What are you going to put this engine in? You may of already hinted, but cant remember. Im jealous here, You have two very nice built engines and a beautiful mean ask looking car. up
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073774
05/15/16 11:32 AM
05/15/16 11:32 AM
Alberta
Alberta
Currently I'm not exactly sure? Always looking around for the right project. Have a couple ideas though. Who knows, it may end up in the Charger yet later this year and I'll find a light weight car for 511 and really go fast!
My big problem is my wife is a Ford fan, so another Mopar may not find its way into my garage anytime soon.
Now...... Will a 440 fit in a fox body? Hmmmm. LOL.
Re: Place your bets, Dyno scheduled this Friday [Re: fast68plymouth] #2073800
05/15/16 12:40 PM
05/15/16 12:40 PM
USA
B3RE Offline
B3RE  Offline
USA
Springs hold to 7000. Drops off bad at 7200
Fast rate cam, 1.6 rockers........ I'm going with valve float. When those things are "done", it's like flipping a switch.
I don't know if you were measuring air flow, but if you were, you'd see it there if that's what it was.
I have to agree. Although we may disagree on the cause, when the power suddenly drops, the valvetrain is unstable, and needs attention.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073810
05/15/16 01:02 PM
05/15/16 01:02 PM
BradH Offline
BradH  Offline
I have no idea what altitude or atmospheric conditions you run in. IMO you should get an accurate on-track weight (sounds like you're just guess-timating it now). Without knowing more specifics, I can't comment on whether the ET & MPH make sense for the HP stated for the 511.
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2073815
05/15/16 01:04 PM
05/15/16 01:04 PM
Alberta
Alberta
I'm just going on the dyno operators opinion. The vacuum gauge we had showed vacuum at 7000. Then as it went higher it was pressurizing they system. But with that said I don't disagree that those aggressive lobes can drop suddenly. Perhaps a combo of both?
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2075616
05/18/16 03:41 AM
05/18/16 03:41 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
How about a bit of an older mustang. I believe this one is named "MoFo"
Page 4 of 4 1 2 3 4
