MSD Blaster II Coil on MP Electronic ignition #2072171
05/12/16 06:22 PM
05/12/16 06:22 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Just installed a MP electronic ignition on a 383. I'm using a Blaster II coil. Do I or don't I use the ballast resister?
Abe Lincoln
Re: MSD Blaster II Coil on MP Electronic ignition [Re: dart4forte] #2072175
05/12/16 06:28 PM
05/12/16 06:28 PM
Ohio
dobie Offline
dobie  Offline
Ohio
I use one. Same set up.
1968 Plymouth Road Runner 383 4 speed
Re: MSD Blaster II Coil on MP Electronic ignition [Re: dobie] #2072197
05/12/16 07:23 PM
05/12/16 07:23 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i would use the ballast resistor.
i bypassed the ballast on my truck using ignition coils that are supposed to be "internally resisted" and i just ended up with overheated coil...
Re: MSD Blaster II Coil on MP Electronic ignition [Re: dart4forte] #2072205
05/12/16 07:37 PM
05/12/16 07:37 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
orange box = use it.
Re: MSD Blaster II Coil on MP Electronic ignition [Re: dart4forte] #2072285
05/12/16 10:29 PM
05/12/16 10:29 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
Same setup using chrome box. Using MSD resistor I believe. Ten years still kicking.
Re: MSD Blaster II Coil on MP Electronic ignition [Re: mikemee1331] #2072417
05/13/16 01:57 AM
05/13/16 01:57 AM
X2, the orange box is problematic enough the way it is. However you have ALOT of leeway on what you can or cannot use/get by with. I dont think you would notice the gain (WO one) but it would greatly increase the chance of a much earlier failure (WO one) (usually at the most inopportune time-Mr Murphy). I'd carry a spare box no matter what.
Re: MSD Blaster II Coil on MP Electronic ignition [Re: Belvedere2] #2072418
05/13/16 01:58 AM
05/13/16 01:58 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I kept mine when I went to that coil, I use a chrome box.
Re: MSD Blaster II Coil on MP Electronic ignition [Re: RapidRobert] #2072516
05/13/16 11:06 AM
05/13/16 11:06 AM
Mesa, Arizona
Mesa, Arizona
Oh yeah, spare box is in the trunk along with a spare resistor
Abe Lincoln
Re: MSD Blaster II Coil on MP Electronic ignition [Re: dart4forte] #2072945
05/13/16 10:42 PM
05/13/16 10:42 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
MSD Blaster II Coil Resistor - 0.8 Ohms
Mopar Performance Makes A 1.0 Ohm Resistor And A 0.25 Ohm Resistor
Why Do We Run A Resistor With A Blaster II Coil And Mopar Electronic Ignition
Because Someone Told Me I Should
Or Because It Looks More FACTORY Running A Resistor And I Have These Wires That I Don't Know What To Do With If I Remove It
I Removed The Resistor Itself Within The Ceramic/Porcelain
Material And Replaced It With A Straight Wire Because
Even Though My 71 Bee Of Course Never Left The Factory With Electronic Ignition To Begin With - Kind Of A Oxymoron
Anyways
Blaster II Coil Painted Black , Mounted Horizontal In The Factory Bracket - Mopar Performance Chrome ECU And Straight Wire Modified Ballast Resistor
Running Strong For A Billion Years
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: MSD Blaster II Coil on MP Electronic ignition [Re: bee1971] #2072960
05/13/16 11:06 PM
05/13/16 11:06 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Anyways
'Just installed a MP electronic ignition on a 383'. this upgrade comes with the orange box. it was assumed the OP was referring to the orange box and not the chrome.
Re: MSD Blaster II Coil on MP Electronic ignition [Re: mikemee1331] #2072974
05/13/16 11:24 PM
05/13/16 11:24 PM
I agree with Mike, the chrome box will tolerate straight thru way better than the orange box will tho you have ALOT of leeway on what you can and cannot get by with. In '83 I used an Accell super coil, the big yellow beast with an HEI module (75 chebby OE black one/VG piece) with the std Mopar electronic dist with NO ballast on a 440 & it was a killer setup/no failure. (Accel later told me to use either a .7 or .8 ohm ballast on it dont remember exactly). YMMV!
