MSD Blaster II Coil on MP Electronic ignition
#2072171
05/12/16 06:22 PM
05/12/16 06:22 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Just installed a MP electronic ignition on a 383. I'm using a Blaster II coil. Do I or don't I use the ballast resister?
Abe Lincoln
Re: MSD Blaster II Coil on MP Electronic ignition
[Re: mikemee1331]
#2072417
05/13/16 01:57 AM
05/13/16 01:57 AM
RapidRobert
X2, the orange box is problematic enough the way it is. However you have ALOT of leeway on what you can or cannot use/get by with. I dont think you would notice the gain (WO one) but it would greatly increase the chance of a much earlier failure (WO one) (usually at the most inopportune time-Mr Murphy). I'd carry a spare box no matter what.
[Re: RapidRobert]
#2072516
05/13/16 11:06 AM
05/13/16 11:06 AM
dart4forte
Mesa, Arizona
X2, the orange box is problematic enough the way it is. However you have ALOT of leeway on what you can or cannot use/get by with. I dont think you would notice the gain (WO one) but it would greatly increase the chance of a much earlier failure (WO one) (usually at the most inopportune time-Mr Murphy). I'd carry a spare box no matter what. Oh yeah, spare box is in the trunk along with a spare resistor
Abe Lincoln
[Re: dart4forte]
#2072945
05/13/16 10:42 PM
05/13/16 10:42 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
MSD Blaster II Coil Resistor - 0.8 Ohms
Mopar Performance Makes A 1.0 Ohm Resistor And A 0.25 Ohm Resistor
Why Do We Run A Resistor With A Blaster II Coil And Mopar Electronic Ignition
Because Someone Told Me I Should
Or Because It Looks More FACTORY Running A Resistor And I Have These Wires That I Don't Know What To Do With If I Remove It
I Removed The Resistor Itself Within The Ceramic/Porcelain Material And Replaced It With A Straight Wire Because
Even Though My 71 Bee Of Course Never Left The Factory With Electronic Ignition To Begin With - Kind Of A Oxymoron
Anyways
Blaster II Coil Painted Black , Mounted Horizontal In The Factory Bracket - Mopar Performance Chrome ECU And Straight Wire Modified Ballast Resistor
Running Strong For A Billion Years
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#2072960
05/13/16 11:06 PM
05/13/16 11:06 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Anyways
'Just installed a MP electronic ignition on a 383'. this upgrade comes with the orange box. it was assumed the OP was referring to the orange box and not the chrome.
[Re: mikemee1331]
#2072974
05/13/16 11:24 PM
05/13/16 11:24 PM
RapidRobert
I agree with Mike, the chrome box will tolerate straight thru way better than the orange box will tho you have ALOT of leeway on what you can and cannot get by with. In '83 I used an Accell super coil, the big yellow beast with an HEI module (75 chebby OE black one/VG piece) with the std Mopar electronic dist with NO ballast on a 440 & it was a killer setup/no failure. (Accel later told me to use either a .7 or .8 ohm ballast on it dont remember exactly). YMMV!
