01/28/09 06:53 PM
01/28/09 06:53 PM
West Tennessee
rbstroker Offline OP
West Tennessee
Can anybody tell me the best place to buy the B&M flexplate (102390) required to put a neutral balance 904 convertor behind a 360 LA engine? Jeg's, Summit, and Mancini are exactly the same price.
Re: 360/904 [Re: rbstroker] #206958
01/28/09 07:08 PM
01/28/09 07:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I prefer Summit for fast delivery time. Usually 3 days.
Re: 360/904 [Re: stumpy] #206959
01/28/09 07:38 PM
01/28/09 07:38 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Summit, and maybe look on the for sale section here.
Re: 360/904 [Re: rbstroker] #206960
01/28/09 08:25 PM
01/28/09 08:25 PM
Lakeside, CA
DartCustom360 Offline
Lakeside, CA
I got mine through Mancini...
Re: 360/904 [Re: DartCustom360] #206961
01/28/09 08:57 PM
01/28/09 08:57 PM
scratchnfotraction Offline
hope you beefed that 904 to go with that 360
I have spit 3 out since march 07 and one today as a matter of fact...super bowl sun and I am R&R a tranny
granted,mine are not beefed and all are jy trannys...all were in good shape at first...
I only have a 318 with a voodoo roller cam
have fun
Re: 360/904 [Re: scratchnfotraction] #206962
01/28/09 09:04 PM
01/28/09 09:04 PM
a cornfield near you
BlakDak Offline
BlakDak  Offline
/\ must be rough on tranny's or just crap luck.
I put several passes on a jy 904 behind a stout 340.
try advanced auto parts, they will match the prices of summit, and should get it in a day also.
Re: 360/904 [Re: scratchnfotraction] #206963
01/28/09 09:10 PM
01/28/09 09:10 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
have fun
Has there been a consistant failure or are they just worn out? I only know of 1 person that can wear out a good 904 that fast and they're making around 600hp.
Original topic - Summit or Jegs for me, I like Mancini because they're all mopar but I don't order from them if I need the parts within the week.
Re: 360/904 [Re: MoparJoe] #206964
01/28/09 11:36 PM
01/28/09 11:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Been many changes over the years with the 904 style trans.
i have a 68 and an 87 in my shop. The 68 has a nice forged band, the 87 has a flimsy stamped steel band with the ears spot welded on. Guess what broke off?
Ran a 360 and 904 in my 72 Dart for years, that specific combo was stock in a 79 Cordoba, the donor for this swap. Dunno how the 79 904 was built like, never had to take it apart. So, yes a 904 can live behind a 360.
Don't be the exception.
Re: 360/904 [Re: rbstroker] #206965
01/29/09 09:03 AM
01/29/09 09:03 AM
West Tennessee
West Tennessee
I was hoping to find someone to beat their prices.
Re: 360/904 [Re: rbstroker] #206966
01/29/09 09:26 AM
01/29/09 09:26 AM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I have a fresh A-999 behind a 450HP 390 Stroker and it works great..... Well, that is after the first trans had the input shaft snap in half
But I think there was a factory defect in the first shaft but I had everthing freshened and it works good with my rowdy little 390...... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: 360/904 [Re: tpabayflyer] #206967
01/29/09 10:51 AM
01/29/09 10:51 AM
5thAve Offline
5thAve  Offline
My 360 killed a few 904s and theres nothing special about my engine. So I got a 727 and havent had a problem ever since.
Re: 360/904 [Re: 5thAve] #206968
01/29/09 11:58 AM
01/29/09 11:58 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
If you use the stock pan on it, you WILL kill it. You MUST use a deep pan, otherwise it runs out of fluid on the 2-3 upshift, and kills the clutches. The 904 is an awesome trans, and I bracket raced them for 7 years. Only had to rebuild it twice in the first two weeks, put a deep pan on it, went the remainder of the 7 years without a single issue....You loose almost 1s in 1/4mile et with a 727 on a mild small block...
Re: 360/904 [Re: rbstroker] #206969
01/29/09 12:18 PM
01/29/09 12:18 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
they're about the best price you're going to find....
FWIW, the lockup 904 in my '86 5th ave held up good behind my headered, comp XE262 cammed 360 until I botched a band adjustment and the spot-welded on tab on the 2nd gear band broke off.
2017 Grand Cherokee Overland
Re: 360/904 [Re: patrick] #206970
01/29/09 01:20 PM
01/29/09 01:20 PM
yea,they are well used,and I hammer them hard
I will try a deep pan on the one I am puting in now
I had every thing from pumps to bands to clutches go at one time or another
I think your right cause it seems to be the WOT 1-2 shift that takes its toll on them for me
then its keep adjusting the bands up till it no worky again
most seem to be the KD band,this last one started whinning and is preety loud,stops when its in park
drove it 40 miles after sitting allday and nothing...then another few miles it starts the whinning..let it sit awhile and it is quit for a mile or 2.....sounds like the pump on this one
I just picked up another A999 out of an 87 dippy that has been rebuilt not long ago...so the jy said
they are poop IMO and they are not working for me
I am looking for a 727...anyone got a good one?
but good luck with yours
Re: 360/904 [Re: scratchnfotraction] #206971
01/29/09 02:14 PM
01/29/09 02:14 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I guess I was lucky then. I ran a 904 in my drag car with a 360 for three years before I stopped racing and never had a problem. I rebuilt the trans myself using a Trans-Go TF-2 kit and installed a new "manual valve" so the convertor would "FILL" in park. I used the stock pan too.
The first two years I was running 13.80's with 3.23 gears and drag radials. The last year I raced I switched to 4.10's, a spool and 29X10.5 slicks and ran 12.70's.
Re: 360/904 [Re: burdar] #206972
01/29/09 03:25 PM
01/29/09 03:25 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
I got mine through Summit. Same combo.. no problems yet.
The Blue Goose
My instagram: Bossride
Re: 360/904 [Re: rbstroker] #206973
01/29/09 08:13 PM
01/29/09 08:13 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
i have a good almost new used one, ran about 2hrs.. its for a 904/318 TC behind a 360.. PM me if interested..
Re: 360/904 [Re: Dakota_Don] #206974
01/29/09 09:06 PM
01/29/09 09:06 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
I've been running a 904 behind my nitrous huffing Slant for years and never hurt anything. 3250# car, launching at 3800 on a brake, w/3.91 gears. 12:00@110.
Re: 360/904 [Re: rbstroker] #206975
01/29/09 09:57 PM
01/29/09 09:57 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Warmed 340 in an Ebody with 904 for 15 years and I beat it. Still performs great.
Re: 360/904 [Re: Dakota_Don] #206976
01/30/09 08:49 AM
01/30/09 08:49 AM
West Tennessee
West Tennessee
Dakota Don PM sent.
This is the land of the free because of the brave
