Zerex G-05 Coolant Leak Cleanup #2068118
05/06/16 03:41 AM
05/06/16 03:41 AM
Utah, USA
1964superstock Offline OP
Utah, USA
Anyone have a good solution for removing chalky residue from dried Zerex G-05 coolant leaks? My thermostat housing gasket leaked and Zerex G-05 coolant 50/50 mix got sprayed everywhere by the radiator fan, love it. Just using water and a rag is not working to get rid of the dried on chalky residue. Something easy on the engine paint and body paint is needed. Would Simple Green or a solution of Cascade dishwashing detergent work? Any good solutions would be appreciated. Thanks!
Re: Zerex G-05 Coolant Leak Cleanup [Re: 1964superstock] #2068129
05/06/16 07:34 AM
05/06/16 07:34 AM
West Virginia USA
P
Palindrome Cuda Offline
P
West Virginia USA
I like to use Go-Jo hand cleaner(without the grit) with different size paint brushs to do under hood detailing on all our cars. I wipe it off with a dry rag or sometimes Murphy's oil soap mixed with hot water and hand wipe. I never spray water on any under hood components.
Bob George Racing sponsored '67 'cuda 9.96 @ 131mph
Re: Zerex G-05 Coolant Leak Cleanup [Re: 1964superstock] #2068284
05/06/16 01:58 PM
05/06/16 01:58 PM
Utah, USA
Utah, USA
Thanks for the reply. I'll give both suggestions a try. If anyone else has some good solutions for cleaning G-05 coolant mess, please add a note. Thanks.
Re: Zerex G-05 Coolant Leak Cleanup [Re: 1964superstock] #2068423
05/06/16 06:05 PM
05/06/16 06:05 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Just call the hotline at Zerex. If they don't have an answer they can tell you some of the ingredients of it. Look at the container. If it's glycol based then try 70% rubbing alcohol. Alcohol is a good solvent and the 30% is water which is also a good solvent and an ingredient. It won't hurt the paint.
Re: Zerex G-05 Coolant Leak Cleanup [Re: A/MP] #2068446
05/06/16 06:53 PM
05/06/16 06:53 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i had the same thing happen with Waterweter and i didnt try to clean it up for a couple of weeks.I didnt find anything that would touch it.keep us posted.
Re: Zerex G-05 Coolant Leak Cleanup [Re: 1964superstock] #2068467
05/06/16 07:37 PM
05/06/16 07:37 PM
Utah, USA
Utah, USA
I called the Valvoline (Zerex) hotline number. They recommended for removing antifreeze leak residue, using a solution of powdered dishwasher detergent (like Cascade) in warm water, along with a soft bristle brush to agitate. So, I guess I try that, and maybe the Murphy Oil Soap later if the the dishwasher detergent does not do the trick.
Re: Zerex G-05 Coolant Leak Cleanup [Re: 1964superstock] #2068510
05/06/16 10:15 PM
05/06/16 10:15 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Water wetter has the same caustic ingredients as dishwasher detergent. It can remove paint. What you might be seeing is mineral deposits or a caustic. It probably has etched the paint. Wash with 50% water and vinegar and a tooth brush. If you still get halos just wipe over with a little plumbers grease(silicone grease) and it will look less noticeable.
Re: Zerex G-05 Coolant Leak Cleanup [Re: 1964superstock] #2068528
05/06/16 10:32 PM
05/06/16 10:32 PM
Utah, USA
Utah, USA
Thanks for the info. I think I'll start with the 50% vinegar and water and brush to start with, seems the least invasive. Then if that does not work, maybe use some Murphy's oil soap, then maybe..palmolive dish soap in a weak watered out solution.
