Where can I find a 1/2" Sending Unit
#2067098
05/04/16 12:33 PM
05/04/16 12:33 PM
Posts: 144 PA
dixie2bird
PA
A friend of mine is rebuilding a 1970 Coronet and is looking to put in a 1/2" sending unit and fuel lines. Does anyone know who sells these? Looks like Summit only has 3/8 and 5/16.
1972 Cuda 340 4-speed 2015 Challenger SRT 392 2015 Jeep Wrangler Unlimited Willy's
Re: Where can I find a 1/2" Sending Unit
[Re: ruderunner]
#2067181
05/04/16 02:55 PM
05/04/16 02:55 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
That is amazing! When I replaced the pickup and sending unit in my '64 Polara years ago all you could buy at the time were the stock 5/16" versions. I made mine by bending up some 3/8" tubing and I thought that was an upgrade!!
I checked both of those sources and it is true...I thought it was a misprint when I read this thread.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: bonefish]
#2067284
05/04/16 05:34 PM
05/04/16 05:34 PM
Posts: 144 PA
dixie2bird
PA
...DANGIT MAN!! im not even gunna tell ya what i just paid for one from MANCINI. Did you also use 1/2" fuel lines? If so, where did you get yours?
[Re: dixie2bird]
#2067482
05/04/16 10:45 PM
05/04/16 10:45 PM
Posts: 1,032 Ohio
dobie
Ohio
Probably. I've had a Herb's, Van's, and one other "brand" that I don't remember. All have read incorrectly. I tried several different gas gauges as well, eliminating those as the issues. It's definitely the newer sending units.
1968 Plymouth Road Runner
383 4 speed
[Re: dixie2bird]
#2067509
05/04/16 11:13 PM
05/04/16 11:13 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I make my own, I picked up about 15 20 foot long pieces from a freight salvage place, paid $7 per stick, it was real parker tubing, some were a little bent but easily made into fuel lines. I also got the parker beading tool, it puts the little bulb on the end of the tube for a hose and clamp. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2067583
05/05/16 01:26 AM
05/05/16 01:26 AM
RapidRobert
What Dobie said, from postings here incorrect reading units are epidemic (worst of any part I have ever heard of) so do your homework so you dont get burnt
[Re: RapidRobert]
#2067768
05/05/16 02:55 PM
05/05/16 02:55 PM
Polarapete
Graham, WA
What Dobie said, from postings here incorrect reading units are epidemic (worst of any part I have ever heard of) so do your homework so you dont get burnt When I built mine (3/8") I swedged and soldered the tubing in place and the heat baked the sending unit so it would not work So I went down to a local shop that sold Mustang parts and found an identical sending unit that fit a '67 Mustang and strapped it to the tubing with zip ties. I put on a new sock and everything worked just fine in the '64 Polara.
