Where can I find a 1/2" Sending Unit #2067098
05/04/16 12:33 PM
05/04/16 12:33 PM
PA
dixie2bird Offline OP
PA
A friend of mine is rebuilding a 1970 Coronet and is looking to put in a 1/2" sending unit and fuel lines. Does anyone know who sells these? Looks like Summit only has 3/8 and 5/16.
1972 Cuda 340 4-speed
2015 Challenger SRT 392
2015 Jeep Wrangler Unlimited Willy's
Re: Where can I find a 1/2" Sending Unit [Re: dixie2bird] #2067103
05/04/16 12:42 PM
05/04/16 12:42 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: Where can I find a 1/2" Sending Unit [Re: dixie2bird] #2067109
05/04/16 12:51 PM
05/04/16 12:51 PM
WA
tman Offline
tman  Offline
WA
Re: Where can I find a 1/2" Sending Unit [Re: dixie2bird] #2067122
05/04/16 01:16 PM
05/04/16 01:16 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Re: Where can I find a 1/2" Sending Unit [Re: dixie2bird] #2067148
05/04/16 02:11 PM
05/04/16 02:11 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Rockauto lists them too!
Angry white pureblood male
Re: Where can I find a 1/2" Sending Unit [Re: ruderunner] #2067181
05/04/16 02:55 PM
05/04/16 02:55 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
That is amazing! When I replaced the pickup and sending unit in my '64 Polara years ago all you could buy at the time were the stock 5/16" versions. I made mine by bending up some 3/8" tubing and I thought that was an upgrade!!
I checked both of those sources and it is true...I thought it was a misprint when I read this thread.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Where can I find a 1/2" Sending Unit [Re: slantzilla] #2067261
05/04/16 04:49 PM
05/04/16 04:49 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Originally Posted By slantzilla
...DANGIT MAN!! im not even gunna tell ya what i just paid for one from MANCINI.
Re: Where can I find a 1/2" Sending Unit [Re: bonefish] #2067284
05/04/16 05:34 PM
05/04/16 05:34 PM
PA
PA
Did you also use 1/2" fuel lines? If so, where did you get yours?
Re: Where can I find a 1/2" Sending Unit [Re: dixie2bird] #2067406
05/04/16 08:56 PM
05/04/16 08:56 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Are these the ones that bad sending units?
Re: Where can I find a 1/2" Sending Unit [Re: dixie2bird] #2067482
05/04/16 10:45 PM
05/04/16 10:45 PM
Ohio
dobie Offline
dobie  Offline
Ohio
Probably. I've had a Herb's, Van's, and one other "brand" that I don't remember. All have read incorrectly. I tried several different gas gauges as well, eliminating those as the issues. It's definitely the newer sending units.
1968 Plymouth Road Runner 383 4 speed
Re: Where can I find a 1/2" Sending Unit [Re: dixie2bird] #2067509
05/04/16 11:13 PM
05/04/16 11:13 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I make my own, I picked up about 15 20 foot long pieces from a freight salvage place, paid $7 per stick, it was real parker tubing, some were a little bent but easily made into fuel lines. I also got the parker beading tool, it puts the little bulb on the end of the tube for a hose and clamp. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Where can I find a 1/2" Sending Unit [Re: astjp2] #2067583
05/05/16 01:26 AM
05/05/16 01:26 AM
What Dobie said, from postings here incorrect reading units are epidemic (worst of any part I have ever heard of) so do your homework so you dont get burnt
Re: Where can I find a 1/2" Sending Unit [Re: RapidRobert] #2067768
05/05/16 02:55 PM
05/05/16 02:55 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
When I built mine (3/8") I swedged and soldered the tubing in place and the heat baked the sending unit so it would not work whiney
So I went down to a local shop that sold Mustang parts and found an identical sending unit that fit a '67 Mustang and strapped it to the tubing with zip ties. I put on a new sock and everything worked just fine in the '64 Polara. up
2008 Honda Element
