340 heat shields #2066190
05/02/16 10:31 PM
05/02/16 10:31 PM
Western New York
sixpackbee Offline OP
Western New York
I never knew there were on both sides. Here are left and right off a 69 340. Do they repop the right side?
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 340 heat shields [Re: sixpackbee] #2066198
05/02/16 10:43 PM
05/02/16 10:43 PM
IN
schmitty Offline
schmitty  Offline
IN
Hi Hek,
Yes they are available. The ones with the part # number on them are quite a bit more cost. Mega parts carries them if I remember right. pm if you have any trouble locating one and I will get one for you. Hope you and your better half are doing Good! Schmitty
Re: 340 heat shields [Re: sixpackbee] #2066204
05/02/16 10:51 PM
05/02/16 10:51 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
So what did the 71 340 E bodies use?
Re: 340 heat shields [Re: UCUDANT] #2066213
05/02/16 11:07 PM
05/02/16 11:07 PM
Western New York
Western New York
I edited the OP. I meant to ask about the right side. I have never seen one or a repop.
1959 Bugeye Sprite
1971 MG Midget
Re: 340 heat shields [Re: sixpackbee] #2066316
05/03/16 01:25 AM
05/03/16 01:25 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
I believe the top one is a 318 the center 2 ports are separate on the 340
NS1AAR
Re: 340 heat shields [Re: ns1aar] #2066459
05/03/16 12:14 PM
05/03/16 12:14 PM
Western New York
Western New York
They are off a 69 340, no doubt. The center may have turned to dust.
1959 Bugeye Sprite
1971 MG Midget
Re: 340 heat shields [Re: sixpackbee] #2066491
05/03/16 01:46 PM
05/03/16 01:46 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Is the passenger side heat shield an early 340 thing? My 1970 340 only had the driver side shield. No gasket on the passenger manifold.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 340 heat shields [Re: sixpackbee] #2066978
05/04/16 04:11 AM
05/04/16 04:11 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My 69 340, passenger side, original factory assembly. SPD 11/8/68. No gasket.
Re: 340 heat shields [Re: sixpackbee] #2067397
05/04/16 08:36 PM
05/04/16 08:36 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
No shield ( or gasket ) on the pass side of any mopar small block.
Look for an OEM part number on the drivers side shield.
McCord did both sides and nether one had an OEM number on them
my money is on they're aftermkt shields
And as an FYI not only is the center divided on the 340 shield. But the exhaust port openings are actually taller on the 340 shield over the 318 shield
