340 heat shields
#2066190
05/02/16 10:31 PM
05/02/16 10:31 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
I never knew there were on both sides. Here are left and right off a 69 340. Do they repop the right side?
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
Re: 340 heat shields
[Re: UCUDANT]
#2066213
05/02/16 11:07 PM
05/02/16 11:07 PM
sixpackbee
Western New York
I edited the OP. I meant to ask about the right side. I have never seen one or a repop.
[Re: sixpackbee]
#2066316
05/03/16 01:25 AM
05/03/16 01:25 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
I never knew there were on both sides. Here are left and right off a 69 340. Do they repop the right side? I believe the top one is a 318 the center 2 ports are separate on the 340
NS1AAR
[Re: ns1aar]
#2066459
05/03/16 12:14 PM
05/03/16 12:14 PM
sixpackbee
Western New York
They are off a 69 340, no doubt. The center may have turned to dust.
[Re: sixpackbee]
#2066978
05/04/16 04:11 AM
05/04/16 04:11 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
My 69 340, passenger side, original factory assembly. SPD 11/8/68. No gasket.
[Re: sixpackbee]
#2067397
05/04/16 08:36 PM
05/04/16 08:36 PM
Posts: 21,489 It's a dry heat
gtx6970
It's a dry heat
No shield ( or gasket ) on the pass side of any mopar small block.
Look for an OEM part number on the drivers side shield.
McCord did both sides and nether one had an OEM number on them
my money is on they're aftermkt shields
And as an FYI not only is the center divided on the 340 shield. But the exhaust port openings are actually taller on the 340 shield over the 318 shield
