I've got a bad headlight switch in my duster and need to replacement. Never done this before so I'm looking for some pointers and advice. Looked under the dash what is the best to get the old one out and the new one in? Is it better to pull the instrument cluster to get to the switch. I see there is a button to push to get the shaft out, then unscrew the lock nut to release the switch from the dash. The trick it appears is being able to the old one out, unplugged, the new one plugged in and back up under the dash.
thanks,
