Power steering pump
#2066264
05/03/16 12:21 AM
05/03/16 12:21 AM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
Will the pressure/volume from a hemi power steering pump work with an older style or borgeson power steering box? I have heard that it won,t, but don,t know for sure. I was planning to add a borgeson steering box to my 64 wagon, but want to know what to expect.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Power steering pump
[Re: AlexP]
#2066743
05/03/16 09:35 PM
05/03/16 09:35 PM
rattler
Crofton, Ky.
Anyone have any reasons to use a Firm Feel box or Borgeson? Is one any better than the other? How do they compare in turns and road feel? Also, can the pressure from a stock Hemi power steering pump be restricted?
[Re: rattler]
#2066923
05/04/16 01:37 AM
05/04/16 01:37 AM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
Anyone have any reasons to use a Firm Feel box or Borgeson? Is one any better than the other? How do they compare in turns and road feel? Also, can the pressure from a stock Hemi power steering pump be restricted? All of the steering play and lack of response is taken out. The steering feels more direct and the car is less likely to wander. It feels more like a rack and pinion steering. I didn't have any luck with turning the Hemi pump and I asked around a ton. I've got about $250 in my whole pump, bracket, pulley and hose set up.
[Re: rattler]
#2077528
05/21/16 03:15 AM
05/21/16 03:15 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
I ran the Hemi pump on the factory PS box for 1500 miles. Input shaft seal started leaking right off, changed it and didn't have any more issues for the 1500 miles.
I then swapped to a borgeson box. That's been in for the last 6,000 miles (of which nearly 20 hours of that is on track road course work, being 20 min sessions at a time mostly) with the Hemi pump. No problems.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: rattler]
#2089833
06/10/16 09:47 PM
06/10/16 09:47 PM
Posts: 106 MI.
mech440
MI.
So does anyone know what power steering pump , G.M. or other wise can be bolted to a gen III hemi but not over pressure the old style gear box?
I know street and performance offers one , but was just wondering if you can buy an off the shelf pump?
I've searched and read many article but noone really seems to have a pump number?
Thanks.
If it doesn't have a motor.....it's not a REAL sport
