Heater/AC Question #2066748
05/03/16 09:38 PM
05/03/16 09:38 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Did non-AC cars come with a water flow valve in the heater hose?
If not, why?
Re: Heater/AC Question [Re: mopowers] #2066817
05/03/16 10:46 PM
05/03/16 10:46 PM
Andrewh Offline
Andrewh  Offline
I want to say no, they didn't.
The blend door directed either fresh air or heated air into the cabin.
since you didn't have to fight the heat with a/c no reason to add a valve.
Re: Heater/AC Question [Re: mopowers] #2066906
05/04/16 01:03 AM
05/04/16 01:03 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
That's what I was thinking. Thanks!
Re: Heater/AC Question [Re: mopowers] #2066915
05/04/16 01:20 AM
05/04/16 01:20 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Where'd the factory typically pull vacuum for the vacuum actuated controls in the heater/ac system? Is it just pulled from the intake manifold?
Re: Heater/AC Question [Re: mopowers] #2066948
05/04/16 02:22 AM
05/04/16 02:22 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes, screw in fitting in back of intake runner where brake booster hose usually goes. a small tube for the heating system. Can be just the small tube straight up if car has no power brakes, otherwise the large one straight up and the small one comes out of the side where the hex is for the wrench.
