Re: Non-Vented Tan Dual Point Caps [Re: DAYCLONA] #2065929
05/02/16 02:38 PM
05/02/16 02:38 PM
MN
Droop69 Offline
Droop69  Offline
MN
Thank you sir!
I ordered one of these from Summit last year (Aug '15). When I opened the box it had the big black vent on it. So I returned it for a refund.
The pic on Summit's website did not show a vent just like Jegs pic. I don't know if they changed the part after the pic or what the deal was. Has anyone bought one recently?
Re: Non-Vented Tan Dual Point Caps [Re: sunroofgtx] #2069475
05/08/16 06:27 PM
05/08/16 06:27 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
I have caps and rotors for sale in the a,b,e body classifieds.
Real Men shift for themselves
Re: Non-Vented Tan Dual Point Caps [Re: 1DGEMAN] #2070011
05/09/16 12:13 PM
05/09/16 12:13 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
PM sent
Re: Non-Vented Tan Dual Point Caps [Re: 71birdJ68] #2084869
06/02/16 10:08 PM
06/02/16 10:08 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
I found the tan cap I took off the distributor in my 71 Challenger 340 and it has the following numbers inside the cap 2444507 which appears to be a Mopar number. I replaced it with the NAPA AL1290. I did a google search using NAPA AL1290 and the pic that comes up shows a non vented tan cap for a dual point distributor which is what I received. I'm purchasing another and will put the two caps side by side in some pics.
Terry
Re: Non-Vented Tan Dual Point Caps [Re: sunroofgtx] #2085542
06/03/16 09:46 PM
06/03/16 09:46 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
2444507 is the part number for a single point cap
dual point is 2585000
Napa part number for the tan cap for dual point dist is AL1680
Re: Non-Vented Tan Dual Point Caps [Re: gtx6970] #2086131
06/05/16 12:29 AM
06/05/16 12:29 AM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
I checked and the old tan cap #2444507 is off a single point distributor. I ordered the AL1290 yesterday and here is from their (NAPA's) web site.
https://www.napaonline.com/napa/en/search?text=ECH%20AL1290
I have a black one that fits on a dual point distributor I have and I'll compare the two. Thanks.
Terry
Re: Non-Vented Tan Dual Point Caps [Re: 71vert340] #2108058
07/11/16 06:45 PM
07/11/16 06:45 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
I finally picked up the AL 1290 NAPA Dual Point cap today and here are pictures of the cap. There's a vent hole drilled behind the one hold down clip, the other one doesn't have a hole. Brass posts.
Terry
20160711_133544 (Medium).jpg20160711_133455 (Medium).jpg20160711_133418 (Medium).jpg
Re: Non-Vented Tan Dual Point Caps [Re: 71vert340] #2108061
07/11/16 06:49 PM
07/11/16 06:49 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Pic of vent hole in cap.
Re: Non-Vented Tan Dual Point Caps [Re: 71vert340] #2108064
07/11/16 06:52 PM
07/11/16 06:52 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Is that for the dual point Dist? The places for the hold down clips look higher than normal.
Re: Non-Vented Tan Dual Point Caps [Re: sunroofgtx] #2108075
07/11/16 07:23 PM
07/11/16 07:23 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes it is for a dual point, a single point cap does not look like that.
Re: Non-Vented Tan Dual Point Caps [Re: 71birdJ68] #2108084
07/11/16 07:33 PM
07/11/16 07:33 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Here's the NAPA cap installed on my dual point distributor. The step the clip snaps on to measures 15/16" from bottom edge of cap to top of step. It runs just fine.
Re: Non-Vented Tan Dual Point Caps [Re: 71vert340] #2108381
07/12/16 12:34 AM
07/12/16 12:34 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Here is an original 2585000 Chrysler dual point cap,the single point has a higher slot and a longer and narrower clip,not even close to the dual point.
Re: Non-Vented Tan Dual Point Caps [Re: 62maxwgn] #2108755
07/12/16 03:05 PM
07/12/16 03:05 PM
MN
Droop69 Offline
Droop69  Offline
MN
That's awesome!
I still have not found a single point cap with brass contacts that does not have that big ugly vent on the top. Anybody have an idea who sells them?
Re: Non-Vented Tan Dual Point Caps [Re: 1DGEMAN] #2391628
10/23/17 05:44 AM
10/23/17 05:44 AM
Colorado
66Hemi Offline
66Hemi  Offline
Colorado
Noted your post for tan, non-vented DP dist cap. Available? NOS 2585000 or OEM equiv? If not, comp to the Echlin AL1290? Thanks!
