Indy 440-1 exhaust port size? #206533
01/28/09 12:32 AM
01/28/09 12:32 AM
Cab_Burge Offline OP
What is the stock height and width of the aluminum 440-1 exhaust port sizes? I have used set that seems like the exhaust ports are big enough to need a special exhaust header flange instead of being able to use a stock size for the normal B-RB heads all comments welcome
Re: Indy 440-1 exhaust port size? [Re: Cab_Burge] #206534
01/28/09 02:09 AM
01/28/09 02:09 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
They`re WAY too big for what your doing........I think you need to send em to me for further inspection and testing.
Re: Indy 440-1 exhaust port size? [Re: Cab_Burge] #206535
01/28/09 02:10 AM
01/28/09 02:10 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
without pulling my headers off i couldn't give you an exact size but i do know std exhaust gaskets don't fit, they overlap the ports big time. the ICH gaskets allow for some extensive porting to make them holes waay bigger.
Re: Indy 440-1 exhaust port size? [Re: rebel] #206536
01/28/09 03:01 PM
01/28/09 03:01 PM
Please, any measurements will be helpful to see if mine are stock or enlarged
Re: Indy 440-1 exhaust port size? [Re: Cab_Burge] #206537
01/28/09 03:20 PM
01/28/09 03:20 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
Cab,I have the first heads that they came out with and they measure 1.5" high by 1.675 wide. I had to grind my hooker comp headers so they lined up better.
Re: Indy 440-1 exhaust port size? [Re: Cab_Burge] #206538
01/28/09 04:23 PM
01/28/09 04:23 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Cab,
440-1 will flow 270cm without the tube with just a cleanup.
As for flanges, any 2" or larger Hooker or TTI flange is adequate. Hope this helps.
8.30's @3400 lbs
Re: Indy 440-1 exhaust port size? [Re: Mike Swann] #206539
01/29/09 12:20 AM
01/29/09 12:20 AM
540Duster, thanks I went out and measured both my 440-1 and my SR exhaust ports, the -1 measure(using a set of dial calipers)1.76 wide x 1.54 high. The SR are 1.665 wide by 1.310 high Dramatic differences I bought a set of the A body Hedman fenderwell headers last year for the Indy heads and have them on the car now on a 440 motor with a set of Eddy rpm heads on it, I will have to remove one side and measure the exhaust port flanges to see if they will work on both the SR and the 440-1 heads, I sure hope so Mike Swann, thanks also
Re: Indy 440-1 exhaust port size? [Re: 540DUSTER] #206540
01/29/09 10:51 AM
01/29/09 10:51 AM
Mo.
racerx Offline
racerx  Offline
Mo.
That's good info....I also have a set of -1's ,with hooker super comp.'s and alway's wonder about the exhaust port opening Got a set of the tti's and have not had a chance two meaure the exhaust port Thax..
Re: Indy 440-1 exhaust port size? [Re: racerx] #206541
01/29/09 12:41 PM
01/29/09 12:41 PM
Please post your findings on the exhaust flange and pipe sizes when you measure them. I hope that I don't have to buy another set of headers or modify the Hedmans, it will be good to know what yours are
