Re: Indy 440-1 exhaust port size?
[Re: Cab_Burge]
#206537
01/28/09 03:20 PM
01/28/09 03:20 PM
Posts: 531 USA
540DUSTER
USA
Cab,I have the first heads that they came out with and they measure 1.5" high by 1.675 wide. I had to grind my hooker comp headers so they lined up better.
[Re: Cab_Burge]
#206538
01/28/09 04:23 PM
01/28/09 04:23 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Cab,
440-1 will flow 270cm without the tube with just a cleanup.
As for flanges, any 2" or larger Hooker or TTI flange is adequate. Hope this helps.
8.30's @3400 lbs
[Re: Mike Swann]
#206539
01/29/09 12:20 AM
01/29/09 12:20 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
540Duster, thanks I went out and measured both my 440-1 and my SR exhaust ports, the -1 measure(using a set of dial calipers)1.76 wide x 1.54 high. The SR are 1.665 wide by 1.310 high Dramatic differences I bought a set of the A body Hedman fenderwell headers last year for the Indy heads and have them on the car now on a 440 motor with a set of Eddy rpm heads on it, I will have to remove one side and measure the exhaust port flanges to see if they will work on both the SR and the 440-1 heads, I sure hope so Mike Swann, thanks also
[Re: 540DUSTER]
#206540
01/29/09 10:51 AM
01/29/09 10:51 AM
Posts: 4,068 Mo.
racerx
Mo.
That's good info....I also have a set of -1's ,with hooker super comp.'s and alway's wonder about the exhaust port opening Got a set of the tti's and have not had a chance two meaure the exhaust port Thax..
