Non-Vented Tan Dual Point Caps #2059869
04/22/16 06:56 PM
04/22/16 06:56 PM
Cleveland
sunroofgtx Offline OP
Cleveland
Hey guys, since no one is making these, wondering if there is a run made, if they would be popular. Brass terminal, ultra heavy duty compression molded, with voltage blocks inside..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Non-Vented Tan Dual Point Caps [Re: sunroofgtx] #2059877
04/22/16 07:08 PM
04/22/16 07:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I go out of my way to find the non vented caps. So, yes I think there would be a demand for them.
Re: Non-Vented Tan Dual Point Caps [Re: sunroofgtx] #2059878
04/22/16 07:09 PM
04/22/16 07:09 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Probably if priced sensibly,last one I bought from NAPA when still available were in the $30/$35 price range.
Re: Non-Vented Tan Dual Point Caps [Re: sunroofgtx] #2059882
04/22/16 07:14 PM
04/22/16 07:14 PM
Kirkland, Washington
Pacnorthcuda Offline
I get the tan color, non-vented, and brass inserts, but what makes a cap dual point?
Re: Non-Vented Tan Dual Point Caps [Re: sunroofgtx] #2059909
04/22/16 07:56 PM
04/22/16 07:56 PM
Cleveland
Cleveland
It has the sprung, graphite contact for the coil contact. The Chrysler Electronics just have a button. These are a lot heavier and have the voltage blockers molded in the inside of the cap..
Re: Non-Vented Tan Dual Point Caps [Re: sunroofgtx] #2060029
04/22/16 11:10 PM
04/22/16 11:10 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have a new tan non vented cap. I will have to check and see if it a dual point cap or not.
Re: Non-Vented Tan Dual Point Caps [Re: sunroofgtx] #2060069
04/23/16 12:21 AM
04/23/16 12:21 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Also different is the notch where it mounts over the distributor body and indexes the cap.
Re: Non-Vented Tan Dual Point Caps [Re: 62maxwgn] #2061975
04/26/16 01:03 PM
04/26/16 01:03 PM
MN
Droop69 Offline
Droop69  Offline
MN
Is that for a single point? Does anyone know the part number (NAPA) for a tan single point cap with brass internals, no vent?
Re: Non-Vented Tan Dual Point Caps [Re: sunroofgtx] #2062145
04/26/16 06:09 PM
04/26/16 06:09 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Considering the last 3 NOS caps I had recently sold in the $175-$225 range, and the avg asking price is $250, and most guys running "correct OEM restos" are usually running a well worn cap (inside) because of the scarcity and price associated with purchasing a "new" cap, or putting on an old "bad" cap just for shows/judging, I'd say it would be a welcome repro, if the price was within reason, quality materials and construction, as well as correct details were maintained, I'd think you have a profitable mover in sales, be nice if you considered reproing all the TAN cap applications...hmmmm
Mike
Re: Non-Vented Tan Dual Point Caps [Re: Droop69] #2062279
04/26/16 09:32 PM
04/26/16 09:32 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
NAPA Dual point tan cap is ECH AL1290 at $19.49 and the single point tan cap is ECH MO20 at $17.49 each
Re: Non-Vented Tan Dual Point Caps [Re: 71vert340] #2063329
04/28/16 01:12 PM
04/28/16 01:12 PM
MN
Droop69 Offline
Droop69  Offline
MN
Thanks for the part numbers!
Re: Non-Vented Tan Dual Point Caps [Re: 71vert340] #2063673
04/28/16 11:30 PM
04/28/16 11:30 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Picture on NAPAs site shows a vent.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Non-Vented Tan Dual Point Caps [Re: DAYCLONA] #2063771
04/29/16 01:35 AM
04/29/16 01:35 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
shock bow
Bought a new MSD billet distributor for $200 & a used digital 6 for $50.. laugh2
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Non-Vented Tan Dual Point Caps [Re: 5wndwcpe] #2063980
04/29/16 01:38 PM
04/29/16 01:38 PM
MN
Droop69 Offline
Droop69  Offline
MN
That's what I saw also.
I don't know if you can get a NON vented tan cap with brass inserts for a single point application. Anyone know?
Re: Non-Vented Tan Dual Point Caps [Re: Droop69] #2064104
04/29/16 04:56 PM
04/29/16 04:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Non-Vented Tan Dual Point Caps [Re: Pacnorthcuda] #2064158
04/29/16 06:30 PM
04/29/16 06:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Dual point is a Prestolite unit and it uses a different cap than the single point/electronic dist.
Re: Non-Vented Tan Dual Point Caps [Re: DARTH V8Я] #2064161
04/29/16 06:32 PM
04/29/16 06:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
shock bow
That stuff doesn't fly on a restoration ...
Re: Non-Vented Tan Dual Point Caps [Re: JohnRR] #2064202
04/29/16 07:59 PM
04/29/16 07:59 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
shock bow
My appologies good Sir. Just had no idea NOS caps were that expensive!
Re: Non-Vented Tan Dual Point Caps [Re: DARTH V8Я] #2064665
04/30/16 01:04 PM
04/30/16 01:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
shock bow
Almost anything NOS and HEMI and/or 6pk is $$$$$$$$$$$$$
Re: Non-Vented Tan Dual Point Caps [Re: sunroofgtx] #2065153
05/01/16 10:27 AM
05/01/16 10:27 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I found a NOS single point cap in the garbage of a house that was being cleaned out for resale.
