440 problems #2064907
04/30/16 08:09 PM
04/30/16 08:09 PM
canada
fast414 Offline OP
fast414  Offline OP
canada
Hey there guys !!!! Tryin to finish my 67 coronet 440 but having a few issues ......
1 when trying to set the timing the balancer is bouncing everywhere
2 i only have 4 psi of fuel pressure .....but it was at 6 psi
3 the car is reving up and down on its own ( between 900-1300 rpm
Any help would be awesome !!!!! Thanks
Re: 440 problems [Re: fast414] #2064963
04/30/16 09:57 PM
04/30/16 09:57 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
What distributor advance springs do you have?
They may be too weak to hold the mechanical advance steady at idle.
Re: 440 problems [Re: fast414] #2064990
04/30/16 10:40 PM
04/30/16 10:40 PM
canada
fast414 Offline OP
fast414  Offline OP
canada
At idle it's ok ...even at 1500 rpm it's ok .....as Sinn as I go higher the spread is huge and I can't set it
Re: 440 problems [Re: fast414] #2064991
04/30/16 10:41 PM
04/30/16 10:41 PM
canada
fast414 Offline OP
fast414  Offline OP
canada
I also took out the points distrib and put and electronic one in and have the same problem
Re: 440 problems [Re: fast414] #2064997
04/30/16 10:56 PM
04/30/16 10:56 PM
canada
fast414 Offline OP
fast414  Offline OP
canada
And it backfires when holding it at about 3000 rpm
Re: 440 problems [Re: fast414] #2065008
04/30/16 11:14 PM
04/30/16 11:14 PM
plugs/plug wires/firing order (esp 5/7) OK/correct?
Re: 440 problems [Re: B5 Bee] #2065013
04/30/16 11:20 PM
04/30/16 11:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What he said, or a vacuum leak
Re: 440 problems [Re: BSB67] #2065019
04/30/16 11:34 PM
04/30/16 11:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Leak would be my 1st guess as well.
Re: 440 problems [Re: Mr.Yuck] #2065168
05/01/16 11:12 AM
05/01/16 11:12 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
fuel pres.bad pump,restriction in line(debris) or worn pump rod. pulsing rpm sounds like a vacume leak.make sure you have your plug wires indexed rite,its easy to get mixed up somtimes.
Re: 440 problems [Re: fast414] #2065725
05/02/16 06:44 AM
05/02/16 06:44 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Hot wire jumper from battery positive to coil positive to ensure that you are getting consistent proper voltage to distributor. Be aware for those running points that you are bypassing ballast resistor so do not run this way for too long as will eventually cause point damage if you are running same.
If all is now well,,,then check all ignition wiring from ignition switch forward to determine if bad switch, wiring, connectors etc, is cause of the erratic idiocyncratic conditions you are experiencing.
Weak or irregular electrical input to coil can cause a wealth of mysterious consequences.
Re: 440 problems [Re: fast414] #2066170
05/02/16 09:47 PM
05/02/16 09:47 PM
dogdays Offline
dogdays  Offline
440 problems and the b.... ain't one!
I know, couldn't help myself.
R.
Re: 440 problems [Re: dogdays] #2066181
05/02/16 10:13 PM
05/02/16 10:13 PM
R.
Dog you lost me, straighten me out!
Re: 440 problems [Re: fast414] #2066246
05/03/16 12:01 AM
05/03/16 12:01 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Google "99 Problems Jay-Z" and you will be enlightened...
Re: 440 problems [Re: DrCharles] #2066302
05/03/16 01:05 AM
05/03/16 01:05 AM
Will do. EDIT Moving picture (video) but no sound, other utube stuff plays OK
