Page 1 of 5 1 2 3 4 5
Billet valve covers #2063721
04/29/16 12:28 AM
04/29/16 12:28 AM
AndyF Offline OP
AndyF  Offline OP
I know a few vendors who make billet valve covers for Chevy and Ford engines but I haven't seen anyone make them for Mopar engines. They are expensive to make, probably cost $650 a set retail. We use them on Chevy dry sump circle track engines since they hold vacuum. Not too many Mopar circle track engines around these days but maybe high end "pro street" type guys might want them?
Re: Billet valve covers [Re: AndyF] #2063732
04/29/16 12:38 AM
04/29/16 12:38 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
looks really good,you get what you pay for!!
Re: Billet valve covers [Re: AndyF] #2063740
04/29/16 12:47 AM
04/29/16 12:47 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
those are like jewelry
Re: Billet valve covers [Re: AndyF] #2063749
04/29/16 12:58 AM
04/29/16 12:58 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
So do tell what would a set for a Predator deal run one smile
Re: Billet valve covers [Re: boatracer572] #2063757
04/29/16 01:16 AM
04/29/16 01:16 AM
AndyF Offline OP
AndyF  Offline OP
Thanks. I designed them with a 1/2 thick rail so they will seal up nice and tight. I put a #12 AN o-ring fitting on one side for the vacuum regulator but left the other side solid to eliminate leaks.
Re: Billet valve covers [Re: Al_Alguire] #2063759
04/29/16 01:19 AM
04/29/16 01:19 AM
AndyF Offline OP
AndyF  Offline OP
I don't have any info on the Predator heads so I wouldn't have any way to design a set of valve covers for them. Indy should have the CNC data on the heads so they should be able to design a set of valve covers without much work. If I had the CAD file for the valve cover rail then it only takes an hour or so to design the cover.
Re: Billet valve covers [Re: Al_Alguire] #2063766
04/29/16 01:29 AM
04/29/16 01:29 AM
San Jose Ca.
San Jose Ca.
X2
Re: Billet valve covers [Re: AndyF] #2063776
04/29/16 01:41 AM
04/29/16 01:41 AM
San Jose Ca.
San Jose Ca.
I could get you that, if your interested in taking on the project.....
Re: Billet valve covers [Re: AndyF] #2063895
04/29/16 11:19 AM
04/29/16 11:19 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Andy,those are extremely nice! up
72 Plymouth Roadrunner 11.08@123.25
Re: Billet valve covers [Re: AndyF] #2063911
04/29/16 11:55 AM
04/29/16 11:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
can you do something with that tunnel ram to bring it up to the standard of those covers? laugh2 those look really good!
Re: Billet valve covers [Re: AndyF] #2063918
04/29/16 12:07 PM
04/29/16 12:07 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Not to hijack this thread but there are billet W8 and B1 covers coming within the next few weeks. Stay tuned for more info.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Billet valve covers [Re: boatracer572] #2063931
04/29/16 12:22 PM
04/29/16 12:22 PM
AndyF Offline OP
AndyF  Offline OP
I could do the project but it would probably be a lot cheaper if you worked with someone like Ultra Pro who has better equipment than me. http://www.ultrapromachining.net
Ultra Pro can build put a valve spring oiler system into the rail of the valve cover and do some other tricks like that which I'm not set up to do.
Re: Billet valve covers [Re: AndyF] #2064047
04/29/16 03:11 PM
04/29/16 03:11 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Do they have clearance on the pushrod side for T&D or Jesel rockers?
Re: Billet valve covers [Re: AndyF] #2064094
04/29/16 04:35 PM
04/29/16 04:35 PM
AndyF Offline OP
AndyF  Offline OP
I don't know about T&D but these covers clear the Jesel rocker arms on my Indy EZ heads.
Re: Billet valve covers [Re: AndyF] #2064170
04/29/16 06:53 PM
04/29/16 06:53 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Maybe machine for rocker arm oil spray inside the top of the valve cover?
Re: Billet valve covers [Re: AndyF] #2064195
04/29/16 07:42 PM
04/29/16 07:42 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
First off, very nice valve covers! But I have to ask cause my knowledge is lacking in this area, what's the difference between your $650 units and other very similar billet ones going for $250? Is it because its the initial run and will get cheaper the more you make? The 1/2" rail? Thanks.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Billet valve covers [Re: 451Mopar] #2064201
04/29/16 07:54 PM
04/29/16 07:54 PM
AndyF Offline OP
AndyF  Offline OP
It is possible to build in valve spring oilers. The shop that built these for me wasn't set up to do that but there are other shops with bigger equipment who can do the oilers.
Re: Billet valve covers [Re: DARTH V8Я] #2064203
04/29/16 08:01 PM
04/29/16 08:01 PM
AndyF Offline OP
AndyF  Offline OP
There aren't any "very similar" billet covers available for $250. If there were I would've bought them rather than have these built.
Re: Billet valve covers [Re: AndyF] #2064207
04/29/16 08:04 PM
04/29/16 08:04 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Thanks thumbs
Re: Billet valve covers [Re: Plumb Wired] #2064209
04/29/16 08:07 PM
04/29/16 08:07 PM
Regina Sask, Canada
V
Viper469 Offline
Viper469  Offline
V
Regina Sask, Canada
Mike Gray
Thats good to know. I was just looking into getting a custom set done for my B-1's. keep us posted. beer
