Valve adjusting tool? #2062126
04/26/16 05:19 PM
04/26/16 05:19 PM
Northern California
lilcuda Offline OP
lilcuda  Offline OP
Northern California
Does anybody use those valve adjusting tools that have the box wrench/allen wrench combo? If so, do they make it easier to adjust the valves?
The last time I adjusted the valves I used a separate box wrench and an allen wrench and it was a pain.
The rockers are Comp Pro Magnums on a small block if it matters.
Thanks for any input.
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: Valve adjusting tool? [Re: lilcuda] #2062169
04/26/16 06:49 PM
04/26/16 06:49 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
yes and no, kind of clumsy, handle to high for leverage to tighten need to go back over with flat wrench to make sure locknuts are tight
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Valve adjusting tool? [Re: lilcuda] #2062206
04/26/16 07:37 PM
04/26/16 07:37 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Valve adjusting tool? [Re: 70AARcuda] #2062292
04/26/16 09:46 PM
04/26/16 09:46 PM
OT if the spec is 20 tho, if a 21 tho feeler gauge has a slight drag and a 19 tho feeler gauge has no drag then you are within 1 tho of spec. there was on old Hot Rod article decades ago that stated that even a few tho off on the adj makes a significant difference in cam timing. I think a dial indicator being carefull to mount it inline would be the best way to confirm the amt of clearance you do have for that part of the deal
Re: Valve adjusting tool? [Re: 70AARcuda] #2062324
04/26/16 10:36 PM
04/26/16 10:36 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By 70AARcuda
It should be for the $.
Fastest 300
Re: Valve adjusting tool? [Re: Crizila] #2062327
04/26/16 10:40 PM
04/26/16 10:40 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I bought their on head valve spring tester.
Not cheap either , but quality costs.
I wish I was rich , but I am gonna bite the bullet and get one of these too I think.
Re: Valve adjusting tool? [Re: lilcuda] #2062355
04/26/16 11:21 PM
04/26/16 11:21 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The LSM tool with the built in torque wrench is great. I have only used a few of LSMs tools but they have all been top notch.
68 Barracuda Formula S 340
Re: Valve adjusting tool? [Re: lilcuda] #2062419
04/27/16 12:49 AM
04/27/16 12:49 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I have their valve spring pressure tester (PC-100)...suprisingly it was extremely easy and handy to use...I got it at a great price (old racer selling off a bunch of his stuff) so it was money well spent...I tell ya, when you use a quality tool all that angst over the high price really goes away and puts a smile on your face! I try to save up over time and occasinally spoil myself with such a quality add-on to the garage tools collection...
Re: Valve adjusting tool? [Re: 70AARcuda] #2062452
04/27/16 01:43 AM
04/27/16 01:43 AM
Northern California
lilcuda Offline OP
lilcuda  Offline OP
Northern California
I saw those on Summit Racing's site. Very nice, but pricey.
Re: Valve adjusting tool? [Re: RapidRobert] #2062455
04/27/16 01:46 AM
04/27/16 01:46 AM
Northern California
lilcuda Offline OP
lilcuda  Offline OP
Northern California
The biggest issue with getting it right on my setup is that it is a Comp XFI hydraulic roller with solid roller lifters. The spec has to be zero lash cold, hopefully opening up to .006" to .008" hot. Not much margin for error.
Re: Valve adjusting tool? [Re: lilcuda] #2062488
04/27/16 02:38 AM
04/27/16 02:38 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
I was of the opinion that hydraulic cams do not have the same ramp as a solid and will not work with solid lifters. Is that different on a roller.
Re: Valve adjusting tool? [Re: lilcuda] #2062534
04/27/16 07:23 AM
04/27/16 07:23 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Solid lifters on a hydraulic cam can work if the lash is very tight.
Been there with a hydraulic flattappet cam. The lash needs to be taken up before/while the camlobe enters the ramp.
Re: Valve adjusting tool? [Re: lilcuda] #2062631
04/27/16 12:15 PM
04/27/16 12:15 PM
Northern California
lilcuda Offline OP
lilcuda  Offline OP
Northern California
According to Comp Cams, this cam can be run this way as long as the lash is kept tight. The reason it is this way is because the hydraulic roller lifters wouldn't clear the block. It's not ideal in my opinion, but I don't have the time or money right now to change it.
AndyF built this engine a few years back. He seems to know what he's doing, so I figure it should be OK.
Re: Valve adjusting tool? [Re: lilcuda] #2062724
04/27/16 02:59 PM
04/27/16 02:59 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Yes, I made my own tool. Yes, it makes adjusting the valves easier.
