440 Nylon Timing Gear #2061750
04/25/16 11:41 PM
04/25/16 11:41 PM
Colo Springs, CO
DconD100 Offline OP
DconD100  Offline OP
Colo Springs, CO
I have a 77 Van style motorhome. Does anyone know if it has a nylon timing gear? Thank you in adavance!
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: 440 Nylon Timing Gear [Re: DconD100] #2061769
04/26/16 12:17 AM
04/26/16 12:17 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Probably not from the factory, but it's a good idea to check.
Re: 440 Nylon Timing Gear [Re: Jim_Lusk] #2061775
04/26/16 12:33 AM
04/26/16 12:33 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Re: 440 Nylon Timing Gear [Re: DconD100] #2061806
04/26/16 01:35 AM
04/26/16 01:35 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
If it was a small block it might still have the nylon.....
Re: 440 Nylon Timing Gear [Re: buildanother] #2061823
04/26/16 02:01 AM
04/26/16 02:01 AM
I'd start by seeing how many degrees the dampener can move before the dist does Be sure to keep the dist tang against the intergear notch for a true reading) cuz it has slop too
