440 Nylon Timing Gear
#2061750
04/25/16 11:41 PM
04/25/16 11:41 PM
Posts: 214 Colo Springs, CO
DconD100
Colo Springs, CO
I have a 77 Van style motorhome. Does anyone know if it has a nylon timing gear? Thank you in adavance!
Pump Gas Small Blocks Rock!
11.53 @ 116mph E85 408 at 8500 ft da,
3605 pound truck, 3.91s, street driven
Re: 440 Nylon Timing Gear
[Re: buildanother]
#2061823
04/26/16 02:01 AM
04/26/16 02:01 AM
RapidRobert
I'd start by seeing how many degrees the dampener can move before the dist does Be sure to keep the dist tang against the intergear notch for a true reading) cuz it has slop too
