Any Cummins mechanics on board?? Need help. #2058352
04/20/16 01:26 PM
04/20/16 01:26 PM
Far Northeast.
mymcodebee Offline OP
Far Northeast.
I have a 2005 dodge dually with 280K miles. I bought this truck new and do not want to bail on it but boy its making it tough.
So I will give a little history and then get to my issues.
It have had four transmissions.
The last one was put in a month ago along with a new transfer case. --- $7,000 invested.
I have a new bed painted sitting in my paint booth for it. $2,000
The front end is all new.--- $1,200
Newer turbo at Carlise.. --- $2,000
All new brakes. $800
Plus a bunch of small stuff I am probably missing.
The cummins has been bullet proof however. Only a valve adjustment at 200K miles.
So now I am getting a very rough idle. Injectors are factory?
There is also a large amount of smoke/fumes coming out of my oil overflow tube.
Yes, it has lost a little power. When I take off it feels like I am under a load even when empty. I first attributed it to the new Chrsler factory trans as it is downgrade over the trans I removed that died. That trans had a large BD torque converter and some upgrades.
Believe it or not I do not beat this truck however it is driven every single day like your typical vehicle you drive to work.
I have just had poor luck with transmissions.
So long story short. Where do I go next. I do not want to drop $77k on a new dually.
Does this sound like the engine is on the way out or is there any chance the injectors are causing the nasty smoke and smell?
Re: Any Cummins mechanics on board?? Need help. [Re: mymcodebee] #2058358
04/20/16 01:35 PM
04/20/16 01:35 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
id be looking at injectors and piston rings.
Sounds like you have blow by, but that's a ton of miles on stock injectors
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: Any Cummins mechanics on board?? Need help. [Re: ViperDave] #2058363
04/20/16 01:41 PM
04/20/16 01:41 PM
Far Northeast.
Far Northeast.
Would it be as simply as piston rings or a complete engine rebuild. Sorry if that's a dumb question but I have no idea..
Re: Any Cummins mechanics on board?? Need help. [Re: mymcodebee] #2058487
04/20/16 04:17 PM
04/20/16 04:17 PM
Guitar Jones Offline
It could be injectors. Find a local diesel injection shop, take them out and have them tested. Check your oil level to see if it's rising or dropping. How good is that used turbo really?
Re: Any Cummins mechanics on board?? Need help. [Re: Guitar Jones] #2058509
04/20/16 04:49 PM
04/20/16 04:49 PM
Far Northeast.
Far Northeast.
Turbo was an $1800 new Chrysler unit. Was a bummer as I could have bought a hi output one for that money but broke down at the car show and needed it fixed the same day.
Re: Any Cummins mechanics on board?? Need help. [Re: mymcodebee] #2058536
04/20/16 05:49 PM
04/20/16 05:49 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
How many miles is your commute?
Mo' Farts
Moderated by "tbagger".
Re: Any Cummins mechanics on board?? Need help. [Re: mymcodebee] #2058670
04/20/16 10:33 PM
04/20/16 10:33 PM
Well, that's a revealing statement. What happened to the turbo?
Re: Any Cummins mechanics on board?? Need help. [Re: mymcodebee] #2058715
04/21/16 12:04 AM
04/21/16 12:04 AM
Maine
jerseybud Offline
jerseybud  Offline
Maine
might want to see these guys in bangor
http://dieselfuelsystems.com/productcart/pc/dfs-services.asp
Thats a ton of miles like was said. Could easily have ruined the engine because of an injector failure. But hope not
Re: Any Cummins mechanics on board?? Need help. [Re: Guitar Jones] #2058721
04/21/16 12:13 AM
04/21/16 12:13 AM
Far Northeast.
Far Northeast.
It was 105 degrees in Carlisle. A $50.00 dirty filter starved my turbo. It did not do any internal damage. Lost turbo three years ago.
Re: Any Cummins mechanics on board?? Need help. [Re: Grizzly] #2058724
04/21/16 12:15 AM
04/21/16 12:15 AM
Far Northeast.
Far Northeast.
A lot! I am self employed and on road all week maybe 40,000 a year. Of course not all in this truck.
Re: Any Cummins mechanics on board?? Need help. [Re: jerseybud] #2058730
04/21/16 12:27 AM
04/21/16 12:27 AM
Far Northeast.
Far Northeast.
[quote=jerseybud]might want to see these guys in bangor
Corey is a great guy and I have been quite a few times. They are 15 mins from my house. He gets $125 an hour to diagnose so I am just looking for another opinion as Corey simply stated start saving up your money to the tune of about $8000. They have not diagnosed anything yet but I hate to spend $500 to find out I need to spend $8k but that might be my only option. Just tough as I keep getting deeper and deeper in this truck that does not owe anything at this point but I cringe to think how much more I need to put in it...
Re: Any Cummins mechanics on board?? Need help. [Re: mymcodebee] #2058774
04/21/16 01:38 AM
04/21/16 01:38 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
If it's got a strong pulse of blow by with the oil cap off at idle coming out of the oil fill hole, the engine is hurt. It's more than likely got some broken piston rings. I have had many of these engines apart and it is common with them. Everyone is quick to blame it on a bad injector but that is usually not the case. Especially if they have a POS aftermarket air filter setup on them. They let too much trash in and wear the rings. Once the rings wear they will begin to flutter in the ring land and eventually break. These engines use a keystone tapered style piston ring which when it wears it will no longer fit tightly in the ring land and break. The broken rings will trash the cylinder wall so it will need to bored or better yet sleeved. Most of the time it is just one cylinder and the others can be salvaged with a fresh hone and fresh rings. It is definitely NEW injector time also.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Any Cummins mechanics on board?? Need help. [Re: 71yelladustr] #2058909
04/21/16 11:44 AM
04/21/16 11:44 AM
I have also seen inoperative injectors cause a lean condition in a cylinder which scuffs and scores the cylinder wall and piston.
Re: Any Cummins mechanics on board?? Need help. [Re: mymcodebee] #2058947
04/21/16 12:46 PM
04/21/16 12:46 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Okay, my first thought was short trips when you posted, which will ruin a diesel.
I run my '02 Cummins a bit like yourself putting 100 to 300 miles a day on it (empty). In colder weather sometimes the idle would slobber/stumble and the cure is to find good long steep hill, keep it in top gear, and pour the coal to it and make it work. Do it a few times. Mine would smooth out and clean up every time. Easy thing to try before digging into your wallet.
It's possible too that you may be on the tail-end of winter fuel in your area, so you can try giving it another month or so just to be sure that's not causing issues. Warm weather and winter blend will affect a Cummins.
Otherwise, wow, some excellent diagnosis posted. twocents Sure hope you get lucky and don't have to go that far though. $
Mo' Farts
Re: Any Cummins mechanics on board?? Need help. [Re: Grizzly] #2058959
04/21/16 01:07 PM
04/21/16 01:07 PM
Far Northeast.
Far Northeast.
Great info guys!! My last question. Is there a reletively simple test to see if my rings are shot. IE compression test?
Thanks again!!
Re: Any Cummins mechanics on board?? Need help. [Re: mymcodebee] #2059032
04/21/16 02:42 PM
04/21/16 02:42 PM
A compression test requires pulling the injectors and special tools most shops aren't going to have unless it's a diesel specialty shop. I would do as the previous poster said and pull the oil filler cap, look for a strong pulse of smoke, if not pull the injectors and have them tested.
I guess you could always pull the intake hose off the turbo with engine NOT running and see if the turbo still spins.
Re: Any Cummins mechanics on board?? Need help. [Re: Guitar Jones] #2059093
04/21/16 03:51 PM
04/21/16 03:51 PM
Far Northeast.
Far Northeast.
It has a chimney of smoke coming out of oil cap when pulled. I will get a pic.
Re: Any Cummins mechanics on board?? Need help. [Re: mymcodebee] #2059121
04/21/16 04:23 PM
04/21/16 04:23 PM
Well then you definitely have excessive combustion going past the rings for some reason.
Re: Any Cummins mechanics on board?? Need help. [Re: mymcodebee] #2059306
04/21/16 10:03 PM
04/21/16 10:03 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Time for an overhaul----My '06 has 512000 with one trans at 299000. Never had the valve cover off......I think it's the best CTD ever built.
Re: Any Cummins mechanics on board?? Need help. [Re: Michael] #2059334
04/21/16 10:42 PM
04/21/16 10:42 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I love those transmissions! runaway Killed two 5.9 Cummins over injector issues, an 04 and an 05. The 04 had an injector go wide open and hydraulic the engine throwing a rod, the 05 had an injector go dead and burn a hole through the piston. They were both due to maintenance issues, the 04 my fault and the 05 the previous owners fault. The fuel filter was plugged up and starved the engine. tsk May be time for a rebuild though as throwing new injectors in it will be a waste of money now. twocents
JB Rhinehart, Realist
A-Body's RULE!
