528 0r 572 hemi build
#2058132
04/20/16 01:56 AM
04/20/16 01:56 AM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
looking for information on either a 528 0r 572 ci Hemi build..reliable 650-700 horse motor on pump gas..street/strip application..what have you guys put together and had luck with??
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
Re: 528 0r 572 hemi build
[Re: 72N96RR]
#2058225
04/20/16 09:31 AM
04/20/16 09:31 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would opt for the 572 (or bigger) for the torque and low rpm, plus you can get away with a less aggressive valvetrain for long life. I know nothing about them, but want to follow this thread to see what folks think of the Indy Cylinder head Legend stuff. We have a lot of Indy dealers on hear, so you wouldn't have to deal with Indy direct. Fast68plymouth is one, Todd Marsh I believe is also.
[Re: gregsdart]
#2058282
04/20/16 11:12 AM
04/20/16 11:12 AM
Posts: 1,033 Madison, Wisconsin
chrisnben
Madison, Wisconsin
I have a 528 hemi with Legend heads for sale in the hemi section. Probably just what you are looking for. Has less than 4000 miles. I can deliver. PM me- your inbox is full!
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
[Re: 72N96RR]
#2058288
04/20/16 11:29 AM
04/20/16 11:29 AM
Posts: 2,656 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Either one is good. If you were using Indy heads I believe you would use their Hi-Po's. I would rather use the Edelbrocks. 700 hp with a pump gas, flat tappet, single 4 bbl, 528/572 is easy. I've put a couple together for my buddies and they are great. The new blocks look good. I buy my components from Ray Barton. It will be fun.
2011 Drag Pak Challenger
[Re: 72N96RR]
#2058298
04/20/16 11:44 AM
04/20/16 11:44 AM
Posts: 12,171 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I am just finishing up my 540 that has been a work in progress for a long time. After talking to several Hemi builders, I went with Ray Barton for the reciprocating assembly and a few other parts. Mostly because of his involvement with the World blocks like I was using. I have been told more than once that the 572 creates a noticeable amount more windage that would need to be dealt with. So I went with the 4.25 stroke. The tires won't hold it anyway.
Master, again and still
[Re: 72N96RR]
#2058425
04/20/16 03:15 PM
04/20/16 03:15 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
I built a 572, but I wanted over 800 hp out of it. A 528 will do what you want easily.
I'm building a pump gas 540" hemi for my dad's car. Unported MP/Edelbrock casting heads, Vanke modded street hemi intake w/ two 750 Carter AFBs, custom hyd. roller. Should be around 600 or better hp in a very mild package.
[Re: 72N96RR]
#2058433
04/20/16 03:25 PM
04/20/16 03:25 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
I would do a 572, or even a 605. There is no replacement for displacement. And more inches doesn't cost a dime more in this instance.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: 72N96RR]
#2058445
04/20/16 03:42 PM
04/20/16 03:42 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
I'm going to assume you have a new block with 4.490 bore, correct? If so look at either a 4.250 or 4.375 stroke crank with the BB Chevy rod journal sizes and use a set of 7.100 long BB Chevy style forged steel H beam rods with 10.5 to 1 compression with iron heads or maybe even up to 11.0 to 1 with aluminum heads for pump gas The heads, exhaust, intake and carbs and cam will deteremine what the exact HP and torque will be EDITED The deciding factor on the stroke length will probally be if you want to run a internal oil pickup or a external oiling system. The longer strokes, over 4.375, especially with the stock Mopar rod journals sizes and stock type OEM or aluminum rods, force you to use a exteranl oiling system to make the rods not hit the interanl oil pickups
[Re: 72N96RR]
#2058933
04/21/16 12:20 PM
04/21/16 12:20 PM
rickseeman
Stuttgart, Arkansas
The Edelbrock Victor Jr's are similar and you don't have to put up with Indy. When I got my Indy HiPo's the installed height was so far off I thought it was impossible. When I got my Edelbrocks I said wow, this is nice.
[Re: 72N96RR]
#2058944
04/21/16 12:43 PM
04/21/16 12:43 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
I went with Stage V heads and had Modern CNC port them. I haven't built the motor yet but the heads seem to be good quality castings. As far as size I'm doing a 540. 4.375 bore and a 4.5 stroke. I can bore to 4.4 and 4.5 in the future if or when required.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: 72N96RR]
#2058966
04/21/16 01:15 PM
04/21/16 01:15 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I went 572" for street/strip/pump gas, and I am well pleased. 10.5 to 1 , Stage V heads by MCH , and a mild solid roller spec. by Dwayne Porter. I am still playing with intake and carburetor choices.
Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: 72N96RR]
#2058972
04/21/16 01:22 PM
04/21/16 01:22 PM
Posts: 701 Southern Maryland
preddy
Southern Maryland
looking for information on either a 528 0r 572 ci Hemi build..reliable 650-700 horse motor on pump gas..street/strip application..what have you guys put together and had luck with?? Talk to Tim Banning at FHO. I'd go with the 572.
