Relocating Magnum power steering return?
#2057085
04/18/16 07:42 PM
04/18/16 07:42 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
The power steering return fitting on the stock 5.2 Grand Cherokee pump is right under my battery tray - too far under to just trim a notch in the tray. I lost it first when I blew a motor mount, second yesterday when I was jacking my engine and forgot about that issue.
I could just JB it back on (again) but I'd rather relocate it away from the tray. Would I be better off plugging the side and drilling a new hole in the back of the reservoir, or putting a hole in the cap and feeding a tube down under the fluid level? There is a baffle inside that keeps me from seeing what's going on in the bottom. Is it just the pump inlet or do I risk hitting anything important inside?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Relocating Magnum power steering return?
[Re: Secret Chimp]
#2057088
04/18/16 07:45 PM
04/18/16 07:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
This in a stock application or an engine swap?
If a swap, relocate the battery?
[Re: Secret Chimp]
#2057094
04/18/16 07:51 PM
04/18/16 07:51 PM
Secret Chimp
Eugene, Oregon
This is a swap into a 67 Coronet wagon. I'm not planning on relocating the battery since I don't really have a rear firewall and the car is 99% street use.
[Re: Andrewh]
#2057176
04/18/16 09:56 PM
04/18/16 09:56 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
Go to the junkyard and find another pump with the return line in a different spot and swap the can out on your pump. Pump can be off a GM or Mopar.
The only Carbs I care about are under the hood!
