MSD Power grid help #2056128
04/17/16 02:18 PM
04/17/16 02:18 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
I just pick up a MSD GRID 7730 and a 7720 ignition controller..anybody out there have any experience with these items..I'm hoping to improve the my 60ft...and take advantage of some of the other options provided...this will be used in a N/A application....looking for dues and don'ts
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: MSD Power grid help [Re: WHITEDART] #2056232
04/17/16 04:51 PM
04/17/16 04:51 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Grab your reading glasses...http://www.yellowbullet.com/forum/showthread.php?t=411336
Re: MSD Power grid help [Re: WHITEDART] #2056258
04/17/16 05:42 PM
04/17/16 05:42 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I used this launch retard to test the new motor. It won't spin, but its far from the fastest...
Re: MSD Power grid help [Re: SpareParts] #2056539
04/18/16 01:13 AM
04/18/16 01:13 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Wow! that made my head explode more than the racepak threads!
Re: MSD Power grid help [Re: WHITEDART] #2056546
04/18/16 01:22 AM
04/18/16 01:22 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Yeah I'll be installing my did and arc module and leash progressive soon... to say I'm nervous is a bit of an understatement
Re: MSD Power grid help [Re: SpareParts] #2056557
04/18/16 01:53 AM
04/18/16 01:53 AM
bean town ....Ca
W
W
bean town ....Ca
I'm not Savvy to the digital racing world...it is going to be a fun I bet.and a bear to wire in...friends laugh at me because I still use a old 6al box. Witch makes it hard to hook this car on a small Tire...on tracks that are not so well-groomed...
Re: MSD Power grid help [Re: WHITEDART] #2056565
04/18/16 02:15 AM
04/18/16 02:15 AM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
I bought this setup last year and cannot believe how I raced before without the grid now LOL, I pull a bit of timing out at the hit and my already consistent 60' is now even tighter. So much more to learn and play with though (adding nitrous soon for catch -up & strategy). One other thing was how much better the car starts, was previously running a 7AL3. Lots of good info there at YB and MSD.
YB Grid Help and at the MSD site MSD Site
Re: MSD Power grid help [Re: SpareParts] #2056590
04/18/16 04:40 AM
04/18/16 04:40 AM
Link no worky help
I have a power grid also, I called MSD to see if it will work with one of thier older non programable digial 7 boxes and they say it will. Now I need to find out what it will and won't do help
Re: MSD Power grid help [Re: Keith Richards] #2056625
04/18/16 08:46 AM
04/18/16 08:46 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Any tips for initial start up?
Sorry about the link, I'm on my phone, harder to copy and paste with big fingers
Re: MSD Power grid help [Re: SpareParts] #2056947
04/18/16 05:12 PM
04/18/16 05:12 PM
Windsor ,Ca.
K
K
Windsor ,Ca.
Squareparts, If you PM me your email I will try and email you my current tune later tonight and you can modify it to your liking , that is what I did with a friends tune initially. One thing they don't do is tell you how to set up the values,etc. real well. I wanted to and do pull 7* out of the timing at the release of the TB to help the running gear (trans) take less initial shock after breaking an output shaft last year. So I pull 7 degrees out after .2 of the brake release and then ramp it back in about 1.7 seconds out, very similar to what Forest has shown above. Lots of endless possibility with it and can record/ watch runs after and see how they all stack up etc. Feel like I still have just touched the tip of the iceberg. lol
Re: MSD Power grid help [Re: WHITEDART] #2056956
04/18/16 05:16 PM
04/18/16 05:16 PM
Windsor ,Ca.
K
K
Windsor ,Ca.
When I went from my 7AL3 to wiring this thing in was easy especially with the plug-in now. Car started right up so if I can do it any one can as wiring has always been a bit of a head scratch-er for me. lol
