-4an brake hose stainless steel #2055712
04/16/16 07:39 PM
04/16/16 07:39 PM
Nampa, Idaho
Moparmatts72 Offline OP
Nampa, Idaho
I know for hard line to calipers are street legal and dot approved but what about the full system all flexible stainless steel hose? Any benefit over a hard line? Thinking of doing a full kit on my street strip 67 dart.
Re: -4an brake hose stainless steel [Re: Moparmatts72] #2055764
04/16/16 10:01 PM
04/16/16 10:01 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Nope. Hose should be kept to the minimum required. Hose actually swells a bit when pressurized. An entire system dome with hose would result in a mushy pedal. Also, the plumbing should be done in 3/16" tubing and -3 hardware and hose IMO.
Re: -4an brake hose stainless steel [Re: Moparmatts72] #2055772
04/16/16 10:17 PM
04/16/16 10:17 PM
Nampa, Idaho
Nampa, Idaho
Okay cool thank you for the info, will just order up some tubing and just bend the system.
Re: -4an brake hose stainless steel [Re: Moparmatts72] #2055934
04/17/16 02:06 AM
04/17/16 02:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
With braided hose all the way you WILL have a spongey
pedal.. thats fact.. run as much steel line as possible
EDIT
I use 3/16 steel on my junk
wave
Re: -4an brake hose stainless steel [Re: Moparmatts72] #2056041
04/17/16 12:02 PM
04/17/16 12:02 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
For years we ran a all -4 hose for the brakes and it was okay. Changed it to mostly steel with a little -3 and much better pedal feel, that would be the way to go.
Good Luck,
Bill
Re: -4an brake hose stainless steel [Re: Moparmatts72] #2056053
04/17/16 12:14 PM
04/17/16 12:14 PM
Nampa, Idaho
Nampa, Idaho
Right now its just -3an hose for a small bit off the wilwood fronts, and hard line on the diff. Was just wondering about from proportioning valve to the flex lines. Will be getting some tubing and bending the hard lines myself. Thanks for all the inputime, first time doing all the brake lines, usually just used the factorules set up.
Re: -4an brake hose stainless steel [Re: Moparmatts72] #2056064
04/17/16 12:34 PM
04/17/16 12:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If this is a race type car with big rear tires and
skinny fronts I would pull the prop valve off.. being
that prop valve was set up for equal size tires all
the way around and for the weight bias of a stock car..
a adjustable prop might be needed
wave
Re: -4an brake hose stainless steel [Re: Moparmatts72] #2056115
04/17/16 01:50 PM
04/17/16 01:50 PM
Nampa, Idaho
Nampa, Idaho
It's just been mini tubed, was thinking of getting a wilwood adjustable one anyways, and plumbing it right off the master then to the rest of the system.
