-4an brake hose stainless steel
#2055712
04/16/16 07:39 PM
04/16/16 07:39 PM
Posts: 99 Nampa, Idaho
Moparmatts72
Nampa, Idaho
I know for hard line to calipers are street legal and dot approved but what about the full system all flexible stainless steel hose? Any benefit over a hard line? Thinking of doing a full kit on my street strip 67 dart.
Re: -4an brake hose stainless steel
[Re: Moparmatts72]
#2055764
04/16/16 10:01 PM
04/16/16 10:01 PM
Posts: 11,589 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Nope. Hose should be kept to the minimum required. Hose actually swells a bit when pressurized. An entire system dome with hose would result in a mushy pedal. Also, the plumbing should be done in 3/16" tubing and -3 hardware and hose IMO.
[Re: Moparmatts72]
#2055934
04/17/16 02:06 AM
04/17/16 02:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Okay cool thank you for the info, will just order up some tubing and just bend the system. With braided hose all the way you WILL have a spongey pedal.. thats fact.. run as much steel line as possible EDIT I use 3/16 steel on my junk
[Re: Moparmatts72]
#2056064
04/17/16 12:34 PM
04/17/16 12:34 PM
MR_P_BODY
If this is a race type car with big rear tires and skinny fronts I would pull the prop valve off.. being that prop valve was set up for equal size tires all the way around and for the weight bias of a stock car.. a adjustable prop might be needed
